Old 09-21-2016, 11:32 AM   #15
2015 30' Classic
Mt Pleasant , South Carolina
I had the exact thing happen on our most recent trip. Voltage dropped to 8.9 and front a/c not working but rear still working , lights dimming, etc. Went to Walmart, bought a Stanley charger, hooked up to batteries and problem went away. Originally thought front a/c was on the fritz but began working immediately as well as all lights,etc. Voltage back to 13.+. While traveling, TV kept batteries up, arrived at campground, hooked up the charger. No problems and continued on trip for 4 more weeks.
Obviously, converter/charger failed and headed to Jackson Center next weekend for another list of warranty items to be corrected. Would encourage you to do the same. I have come to not trust local dealers and the factory service is second to none. Hope this helps.
SC RVer is offline   Reply With Quote
Old 09-21-2016, 11:53 AM   #16
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I'm not understanding why going to store mode kills the AC and outlets. If this is a trailer with two AC inputs, one for shore power and one for generator, and a transfer switch, and the converter is bad, and the transfer switch needs 12 volts, that could explain it. You could try to moving the shore power cable to the other (generator) connector; that might restore shore power to everything else.
This will not help the lack of battery charge from a failed converter. An inexpensive auto charger as previously suggested could keep your batteries charged until you can get into a dealer for warranty repair.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-21-2016, 12:02 PM   #17
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
Al
The air conditioner requires both 12v (for the thermostat) and 110v (for the compressor and fan). If the converter is not functioning and providing the 12v, the batteries will take care of that until they run out -- or -- until you click the Use/Store switch to Store. At that point, there's no 12v, and therefore no AC.
Turning off the breaker to the converter, switching Use/Store to Use, and putting a charge on the batteries saves the vacation. Any qualified RV service center can replace the converter when the trip is over. Keep the trip going, and wait until you find a service center with a good reputation that will not require you to live in their parking lot for a week or more.
teagues is offline   Reply With Quote
Old 09-21-2016, 12:18 PM   #18
Thanks, that explains the AC. The outlets must be a transfer switch issue. Moving the shore power cord might fix the outlets, but not the AC. The inexpensive battery charger is the best (and only complete) solution. I'm still getting used to the fact of 12V thermostats. My previous trailer had a thermostat built in to the unit and only required 120VAC to operate.
Al
S/OS #004
Old 09-21-2016, 12:42 PM   #19
teagues's Avatar
2008 20' Safari SE
Al
The 12v thermostat makes more sense if you consider that it's responsible for the AC/Heat Pump and the furnace. You cannot run the AC without shore power, but you can run the furnace on batteries alone. To have a single thermostat that runs everything, it needs a 12v source that does not require shore power. Not saying that's the only way they could have done it, much less the best way to do it, but that's what they did.
Old 09-21-2016, 12:50 PM   #20
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by YodaBuddha View Post
My wife and I would be so grateful for any thoughts anyone might have on this.
Hello YB.
It's notoriously difficult to diagnose electrical problems over the internet, so I'm going to try to steer clear of that as far as I can. However, I will offer several observations and suggestions.
1) I understand you have a new 27' FC. I believe that the converter is connected to 120v power in these models using an ordinary household cord and plug. Therefore, you can unplug it! That should address any concerns about fire safety while connected to shore power. (As an aside, if it's already unplugged, you might have found your problem. As another aside, you can plug it into an extension cord and a known good outlet as a troubleshooting measure)
2) As others have pointed out, you can use any ordinary automotive battery charger as a temporary interim measure.
3) You can also exchange batteries between your tow vehicle and the Airstream, although it is possible that the Airstream battery will be a little too large to fit physically in the available space in the tow vehicle (depends on vehicle). This is often the fastest way to get power to your Airstream for a night to buy some time and spousal happiness. (You may end up having to jump start your vehicle however and it can be a little tough on vehicle alternators to charge really dead batteries)
4) I would be very surprised if there will be a problem with warranty coverage as a result of you making the necessary repairs to get through your trip.
5) Most areas have someone in the "mobile RV repair" business. That is a service that is ideal for the situation you are on although obviously you will have to pay them unless you can somehow convince Airstream to do so (possible but unlikely, I'd try having that conversation with the dealer you bought the trailer from). If the converter has to be replaced, you're looking at maybe a $300-$400 repair all told.
6) Finally I will point out that while converters do fail even while fairly new, it is perhaps more common for the wiring to them to fail, either on the AC or DC side.
Old 09-21-2016, 02:00 PM   #21
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
We had a similar problem with our 2007.when away from home during the winter. I purchased a battery charger and charged the batteries until I was able to find a new converter. If your concerned about the converter running and a fire hazard you should be able to shut off with its circuit breaker. The refrigerator controls are on the 12v D.C. System and may not have enough voltage to work. The control system for the ac, heat and fan on my 2007 Safari uses 120 v a/c and 12v D.C. So that may explain why the a/c is not working. I can't figure out why your outlets are not working when the battery switch is in the store position. The only outlets not working should be the one connected to your inverter. Changing the converter is not a big job but I would wait for a Airstream dealer to do it under warrantee. Good luck.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 09-21-2016, 02:00 PM   #22
2015 27' FB International
Wheatley , Ontario
Originally Posted by dwightdi View Post
You could just buy a $35 110 volt 10 amp battery charger from Walmart (or similar) and back charge the batteries by plugging in through the 12 volt cigarette lighter outlets in the coach. It worked for me, until I could get home to really fix the problem.
x2 ...
lovetokite is offline   Reply With Quote
Old 09-21-2016, 02:46 PM   #23
1978 31' Excella 500
Barrie , Ontario
I didn't know rv and auto batteries sold /used in the U.S still had to have the water level checked. These are no longer sold in Canada only sealed batteries because of the danger of spillage, I remember the old car batteries and the damage the leakage or spillage could do to clothes and surfaces.
Bev1940 is offline   Reply With Quote
Old 09-21-2016, 03:49 PM   #24
2007 22' International CCD
Converter failure in the middle of a big trip - advice needed
There are a wide variety of batteries available in the US still. I have noticed a trend away from fully sealed batteries for automotive use. All my current vehicles have batteries that do use little water, but it is still possible to add water if needed.
My AS uses golf cart style batteries that need water regularly. I find this a bit of a pain, but they are cheaper and more available in more places than sealed AGM style batteries. My stock charger needs to be replaced before I even consider AGM batteries. So I'm stuck with flooded batteries for now.
KE4GNK/AE
Old 09-21-2016, 04:01 PM   #25
2015 25' Flying Cloud
Morton , Illinois
As sgt. Shultz would say "I know nothing" but I sure learned a lot reading these messages. I would like to continue following any further posts but I cannot see any way to follow this thread. Can someone splain?
Hobo
Hoboplayer is offline   Reply With Quote
Old 09-21-2016, 04:13 PM   #26
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . don't know which way you're headed, but there's AS dealers in ABQ & Tucson, I'd give them a call and ask. . . In the meantime backcharging batteries seems like it would work , at least temperarily. . . good luck, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 09-21-2016, 05:16 PM   #27
MsTara's Avatar
2017 16' Sport
Vernon , Arizona
There is also an Airstream dealer in Phoenix (Mesa) called Desert Autoplex.
I look forward to hearing more details and hope that your trip gets back on track.
MsTara is offline   Reply With Quote
Old 09-21-2016, 05:44 PM   #28
2015 25' FB Flying Cloud
santa fe , New Mexico
I changed the stock converter in my 2014 25' to a multi stage model. I would be happy to ship the stock one to you if you pay the shipping. Easy install.
Good luck,
Tom
tmcguffy is offline   Reply With Quote
1st Big Trip, 1st Big Issues! trekerboy On The Road... 17 07-13-2016 07:07 AM
Maiden Trip Cut Short: Converter or Batteries Failure KJRitchie Batteries, Univolts, Converters & Inverters 50 07-06-2014 11:27 PM
Big Big Trip...11 Day Countdown!! weirdstuff On The Road... 11 05-31-2014 08:01 AM
follow-up to Maiden Trip Cut Short: Converter or Batteries Failure sldflyfish Electrical - Systems, Generators, Batteries & Solar 15 05-21-2013 03:08 PM
Middle Twins to Middle or Rear Queen? fastrob General Interior Topics 12 02-27-2006 02:12 PM
