Old 06-17-2018, 01:54 PM   #1
Delta , Pennsylvania
Collins Subwoofer
2017 27FB Flying Cloud, last trip out subwoofer was making so much distortion I pulled out the jack wires, didn't have time to investigate. Now at home reconnected jacks and nothing, doesn't seem to be working at all . Any one else had the issue. Collins IC100 subwoofer.
Tbuck is offline   Reply With Quote
Old 06-17-2018, 07:40 PM   #2
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
For the distortion, there are two adjustments one being the volume which I turned down. The other is the by pass range, which I adjusted downward cutting the higher frequencies off. This improved the sound significantly. You will need to adjust the bass on the radio by turning it down also.
As for getting it to work again, story can't help you. Degree is in music not electrical engineering.
Matti
Mattirs is offline   Reply With Quote
Old 06-18-2018, 05:48 AM   #3
2018 27' Globetrotter
1993 30' Excella
Flushing , Michigan
Not sure if this helps, but here is my story. The Polk audio system in our new Globetrotter does not work, even after the dealer swapped the unit out for a different new unit--they are working on it now. I should note that the Polk unit LOOKS like it is working from the display. I did take a couple of photos of the backside of the subwoofer and it does appear that two white wires that go into the "block/connection" are cut--is this the problem?
ID:	314375   Click image for larger version
steve46 is offline   Reply With Quote
Old 06-19-2018, 03:31 AM   #4
Mine are cut also, it worked fine for almost a year.
Thanks for you input.
Collins subwoofer lkuzel Audio, Video & TV 3 10-30-2017 10:29 AM
Collins 8" Subwoofer IC 100 WanderStream Airstream Classifieds 0 12-13-2015 03:11 PM
Looking for someone in Fort Collins,Co who works on air streams Colleenwl Hitches, Couplers & Balls 5 02-24-2015 01:53 PM
Ft. Collins, CO campgrounds?? gowest1969 On The Road... 12 10-12-2014 08:44 AM
Fort Collins to Phoenix azflycaster On The Road... 12 11-12-2009 02:03 PM
