I do so hope someone can help me.
I have a Coleman mini Mach ac unit on my
1963 airstream safari that blows but (recently) no longer cold air. I think it may be the starter or running capacitors, however the sun has bleached the product info so I don't know which model it is. I have info from the capacitors housings which I photographed.
I hope you can help in 1: identifying if the problem is likely to be the capacitor? and indeed which one if not both? (my understanding is that the third is for the 'fan' but it works)
2: Advising me of the capacitor replacement numbers I need (I can get you the photos or easily transcribe their numbers)
And 3: Are you able to identify the actual Coleman mini Mach model number from the capacitor info I have which would be a great help.
Finally, if you could advise which replacement/s and where to get them or who I should approach if you are unable to help.
Very best regards
Robert Burns
