Old 09-06-2015, 01:31 AM   #1
2008 532 International
New Braunfels , Texas
Co2 Sensor
2008 International 25 FB. Owned it a week now- preparing for first long weekend.
Put new AA's in the Co2 sensor and it beeped. Thought, "Okay- it is working, cool!" Then it beeped again. And again- every 20 seconds or so. Maybe 30 seconds? Well, about as long as it took to be convinced that it was not going to do it again and walk away- then again.
Haven't got propane in the tanks yet or fired up anything other than a generator to power A/C and lights.
Thoughts. suggestions (in laymans terms, please?).
Thank you in advance!
StreamGlider is offline   Reply With Quote
Old 09-06-2015, 03:05 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
One beep every 20 or 30 seconds sounds like a fault code.
Most likely cause is that the CO detector is just too old. If it's the original one, it's seven or eight years old (depending on whether your 2008 Airstream was built in 2007 or 2008), and the sensor in every detector goes bad over time. The usual replacement interval is about every five years.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-06-2015, 05:59 AM   #3
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Yep, mine was doing the same thing (in the trailer) it is only good for about 6 years. Replace it.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 09-06-2015, 06:21 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
When did you last replace the batteries?
Old 09-06-2015, 08:22 AM   #5
Gainesville , Florida
CO not CO2.
Old 09-06-2015, 08:29 AM   #6
Originally Posted by avionstream View Post
CO not CO2.
Ha, you're right.
I put new batteries in yesterday.
Where can I get a replacement and at the best price? is it an Airstream only part or interchangeable with other types?
Thank y'all, for the insight.
Old 09-06-2015, 08:42 AM   #7
Ace hardware, Home Depot.
Old 09-06-2015, 10:11 AM   #8
2012 28' International
Prince Edward County , Ontario
Ours went after two years; we tried new batteries but to no avail. We couldn't find the same brand that Airstream installed and had a hard time finding a CO detector that would fit over the old screw holes in the bulkhead as the new ones we found were all rectangular in shape and not circular like the original. We finally found one at either Home Depot or Lowes however it's a combination CO/smoke detector and quite pricey. We bought it anyway as it covered the old screw holes. It has a permanent battery installed which is supposed to be good for 10 years.
Cyclist is offline   Reply With Quote
Sewer Gas Smell in Trailer - Co2 Detector Went Off breezyway Plumbing - Systems & Fixtures 11 08-04-2014 04:03 PM
CO2 alarm srpuywa General Repair Forum 14 09-05-2013 12:31 PM
Need smoke AND CO2 detectors? CA_Tallguy LP Gas, Piping, Tanks & Regulators 19 08-12-2013 11:13 AM
Where is the Speed Sensor? (Allison Tranny Error) Griffin Mechanics Corner - Engines, Transmission & More... 4 12-16-2003 04:57 PM
gas tank sensor wb13798 Mechanics Corner - Engines, Transmission & More... 21 08-21-2003 06:04 PM
