Old 06-17-2015, 12:10 PM   #1
2010 27' FB International
Simi Valley , California
Closet sewer smell
2010 International 27FB
My closet has a distinct sewer smell. This smell, is also present under the closet in the access area.
I understand the cleanliness, negative air pressure, stoppers, etc. but that does not address the problem, only band-aids it.
I had the gray tank valve open and thought maybe that was the problem. I closed it and no change. I then disconnected from the dump connection to be sure it wasn't somehow coming from there. It is still present. The trailer has not moved for several days and the smell, as far as I noticed, popped after we had been sitting (level).
I'm considering sealing the closet area, but that is also just a band-aid.
Any ideas?
Steve_M is offline   Reply With Quote
Old 06-17-2015, 12:21 PM   #2
Lily&Me's Avatar
Normal , Illinois
Have you checked your black tank, and/or the location of that vent?
Our black tank vent is on the roof, directly over the closet.
Maggie
Lily&Me is online now   Reply With Quote
Old 06-17-2015, 12:35 PM   #3
1994 34' Limited
Round Rock , Texas
I have this same problem. My vent pipes run through the closet to the roof, and both of the vent pipes do not appear to be loose, or have holes in them. I am curious to see what others say on this one.
To date, I have ripped out all the carpet in the closet, and have sprayed it with vinegar to try and kill any smells. Not sure its really made a difference though.
txtwin is offline   Reply With Quote
Old 06-17-2015, 12:38 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
In my trailer there is a vent check valve under the galley sink. It is supposed to be closed except (I think) when the sink/and or gray tank is draining. The output of the check valve is on the gray tank side of all P-traps. If you were connected to sewer with your gray valve open, odors from the sewer system could be absorbed by liquids and solids in the gray tank and drains and could leak past a defective vent check valve. Apparently this meets code because in normal operation there should be no sewer gas to vent inside the living space. My trailer is a 2001 so I'm not sure yours is plumbed the same but I bring this up for your consideration.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-17-2015, 02:41 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If you remove the vent cap on the roof, you may notice there is no "sealant" between the sewer vent and the AS shell.... Stinks inside real bad like that.
I sealed around it on the outside with "electrical putty".. Plumbers putty may work just as well. I then replaced and properly sealed the Vent cap.
No mo "Peppy LePhew"!
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-17-2015, 03:32 PM   #6
1994 34' Limited
Round Rock , Texas
Can you tell me more about this? I was on the roof this weekend, and there is a putty all around the outside opening of the sewer vent, but not sure about the inside. I did look down the pipe, and the rubber flapper is worn out. Couple questions with that. Is water getting down that pipe and filling my gray water tank? Second, do I need to seal the inside of the pipe as well as the outside? Is there a way to replace the worn out flapper, or do you just replace the entire vent?
Thanks for the help.
Old 06-17-2015, 05:08 PM   #7
Under my closet
As you can see from the photo the vent (I don't know if this is for the gray, black or both) terminates under the closet. Also I'm not sure what flexible "vent" is tying into the furnace ducting.
Old 06-17-2015, 05:16 PM   #8
Here's the pic
Did that pic attach wrong. Here it is.
Old 06-17-2015, 06:19 PM   #9
2017 25' International
Joliet , Illinois
On top of that black pipe is an Auto-Vent. Pop the cap off and check the diaphragm in side. Make sure it is not deformed, clean and seats properly. Also make sure the spring is o.k.
bel73 is offline   Reply With Quote
Old 06-17-2015, 06:30 PM   #10
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
As a troubleshooting procedure you could tape a plastic bag tightly over this valve and see if the the closet stinks. If so I think I would replace it, they're not expensive.
Doug and Cheryl
Old 06-20-2015, 07:43 AM   #11
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Lowes sells these autovents for about $10. I changed mine. When I removed the old (original) one, I noticed that there was no proper sealant - it should have either teflon tape or vaseline on the threads when screwed on to ensure that no air (read "phew") gets out.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 06-20-2015, 10:42 AM   #12
I appreciate all of the comments and will be replacing the vent, which does appear to be the problem. Thanks again
Old 06-20-2015, 09:34 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
On our 34', the tank vent penetrates the roof. There was a "ventline" vent cap surrounding it and screwed to the roof.
I removed the vent cap only to find the vent pipe wobbling around in the sloppy hole in the roof. I pressed in a ribbon of "plumbers putty" to seal it off and followed with a topcoat of sealant then plopped the cap down and replaced screws... Problem solved.
Channing
WBCCI# 30676
Old 03-06-2016, 08:59 PM   #14
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
On my 2015 27fb I have the same strong sewer smell in the closet. (no smell under the closet) This happens when we travel down the hwy with sewer in the tanks. It is especially bad when the fantastic fans covers are open for cabin ventilation in hot weather. The dealer has looked at it twice and still have the problem.... may have to make the 1000 mile trek to Jackson Center. I don't think its from the grey tank... thinking it from the black tank. Next test is to drain just the grey tank and tow to check for smell. Any ideas?
"Ferdara" Mark and Michael Broussard-Hubbard
Aluminum pulling Aluminum 2018 F-150 4X4 Platinum, 3.5L V-6, 10 speed trans, 6.5 bed, Max Tow 3.55 Elec Locking axle, Roadmaster Active Suspension ~ 2015 Airstream Custom Ordered 27fb International Serenity - Lafayette Louisiana
WBCCI 11100
LaBigDogs is offline   Reply With Quote
Sewer Gas Smell davespann Waste Systems, Tanks & Totes 18 07-24-2016 08:57 PM
Smell in closet britabeck General Repair Forum 3 08-04-2014 07:56 PM
Sewer Gas Smell in Trailer - Co2 Detector Went Off breezyway Plumbing - Systems & Fixtures 11 08-04-2014 04:03 PM
2012 Flying Cloud 25FB - sewer smell jjnail General Repair Forum 3 05-13-2014 02:29 PM
Smell in back Closet Near Toilet? antmagrat Waste Systems, Tanks & Totes 14 07-23-2008 06:01 PM
