Old 01-02-2019, 12:52 PM   #1
2017 30' Flying Cloud
chattanooga , Tennessee
closet floor fell
I have a 2017 Flying Cloud 30 that my closet floor has come loose an fallen. Anyone experience this? Thoughts on self fix? Thanks
Name:	Closet floor fell.jpg
micmooch is offline   Reply With Quote
Old 01-02-2019, 02:08 PM   #2
eganwh's Avatar
2016 27' Eddie Bauer
Billings , Montana
If your closet is similar to the 27FB, then the back of the closet floor is supported only by the overhanging trim covering the utility inlet area.
I preemptively fixed my floor before it fell in by adding a leg that supports the center section of the floor near the back.
I had taken the closet apart (which is a real PITA because of all the pocket screws) to add a hard wired surge protector so I took the opportunity to fix it at that time. Good luck!
Attachment 330909
eganwh is offline   Reply With Quote
Old 01-02-2019, 02:14 PM   #3
Long Island , New York
What a classic "latent design defect" Airstream has foisted upon both of you, and other owners of similar units!
An entirely shoddy construction detail, which could be reasonably foreseen to fail at some point. Burying such a defect so deeply, that the eventual failure would likely take more than 2 years to unfold, does not absolve a manufacturer of liability.
Lucky for Airstream that no one was injured by putting their full weight on that floor, only to have the flimsy support system fail catastrophically!
AS should cover this work under warranty IMO, even after the standard warranty period.
Old 01-03-2019, 10:29 AM   #4
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Attachment 330909
Hi micmooch,*
We're very sorry to see this. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 01-03-2019, 05:54 PM   #5
2017 30' International
Charlotte , North Carolina
Exact same thing happened to our 30 International, 2017 year model.
I cobbled up some reinforcements as I discovered it right before a trip.
If this is a warranty item, it would be nice to know as it is at dealer now.....
Al U. Minium is offline   Reply With Quote
Old 01-03-2019, 06:19 PM   #6
Call the dealer and demand a warranty repair. You might direct them to this thread, and Airstream's reply in Post #4.
Good luck!
Peter
Old 01-03-2019, 08:27 PM   #7
wulfraat's Avatar
Broomfield , Colorado
closet floor fell
Same thing happened to me on my 2017 30 (same floor plan, same closet). Same thing.
We ended up re-constructing the interior of the closet and replacing the balsa wood floor, substantially reinforced everything, and turned into a pantry to include 120v power and an ice maker.
Bombproof now.
ID:	331011   Click image for larger version
wulfraat is offline   Reply With Quote
Old 01-03-2019, 08:46 PM   #8
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Who in their right mind would ever expect to stand on the closet floor and have it hold them? Who could even fit into the closet to stand on the floor? I want whatever your smokin'.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 01-04-2019, 07:33 PM   #9
TahoeStream'n
subfan1's Avatar
2019 23' International
La Habra , California
Our 2019 23CB closet floor failed as well. The floor is pocket screwed in one side and the other side only has 2 screws at the front holding the floor. The entire back and most of the side is dangling. Airstream did cover our closet floor under warranty. They added a L shape aluminum bracket along both sides front to back and we are happy with the results.
2018 GMC Sierra Denali
2019 23CB International
subfan1 is offline   Reply With Quote
Hall closet floor collapse... DHart Repairing/Replacing Floor &/or Frame 19 09-17-2015 10:00 AM
'68 Overlander wet closet floor...where's the leak??? Anajojo Sinks, Showers & Toilets 5 10-22-2012 03:01 PM
Closet flange and new cork floor. desertair27 Sinks, Showers & Toilets 3 06-17-2011 05:10 PM
Step problem--bolt fell out--inaccessible Kistler Steps 4 08-24-2003 01:07 PM
Daughter fell out of the trailer... Safari Tim 1969 - 1973 Safari 12 07-22-2003 10:01 AM
