Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-30-2015, 01:10 PM   #1
rowdyATX's Avatar
1956 26' Cruiser/Overlander
1961 28' Ambassador
Clecos grip range
What grip range should be used for repairs?
rowdyATX is offline   Reply With Quote
Old 04-30-2015, 01:39 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
You are typically riveting a few sheets of aluminum together, so a large grip range is not really needed. The "generic" clecos that Vintage Trailer Supply sells will get you from 1-1/4" which was more than enough for the work I did (and I did a shell-off with panel replacements, vent replacements, etc.).
Spring Clecos
Old 04-30-2015, 03:05 PM   #3
rowdyATX's Avatar
1961 28' Ambassador
Thank you Bele
How many clecos? bass-o-matic General Repair Forum 6 06-20-2014 06:29 PM
How do I clean Vulkem from Clecos? rumrunner Ribs, Skins & Rivets 5 08-05-2013 07:50 AM
Anyone tried diamond or coin grip rubber flooring? tvanwave Floor Finishes 6 11-27-2010 11:43 AM
Clecos - will I wish I had 'em? Old Nuke General Repair Forum 24 03-11-2009 05:33 AM
Rivet Grip Strength monocoque Ribs, Skins & Rivets 10 04-12-2008 09:58 PM
