Old 11-23-2007, 11:49 PM   #1
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Cleaning the gap?
Ok, for the forth time my stall is beign re-caulked. First time by factory when installed. Second by the factory, third and forth by me. The caulk keeps pulling away from one side or the other. This all in less than two years.
I have removed all the old caulk and cleaned as best I can. It is a relatively small gap and the only things I can think of to clean the gap further will disolve the shower stall. De-natured alcohol is my non-melting solvent of choice. However just spraying it in there will do not good. I do not have room to get a cloth in there most of the way around.
Any suggestions on cleaning the gap so the caulk will stay stuck this time?
Michelle TAC MT-0
Sarah, Snowball
Old 11-24-2007, 06:44 AM   #2
If the sealer fails without towing the trailer, that's one problem.
If the sealer fails when you tow the trailer, then the problem more than likely is improperly balanced running gear, and/or a super heavy duty tow vehicle equipped with excessive rated torsion bars.
Airstream trailers love a soft ride. Anything that contributes towards a rough ride, will cause many different things to happen, since the shell would be forced to flex more than it's designed to normally handle.
Vibrations and road shock, unless they are minimized, contribute very heavily towards many different damages, up to and including frame and shell fatigue, water leaks, shearing of rivets and the like.
Old 11-24-2007, 06:56 AM   #3
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
For what it is worth,some of the higher quality paint stores (as in not Sherwin Williams) will carry a brand of caulk that is called Big Stretch,its great stuff and as the name implies it stretches alot more then normal caulks ,and does'nt ever dry hard and brittle,Hope this helps
Rollerboy is offline   Reply With Quote
Old 11-24-2007, 06:56 AM   #4
Druupy's Avatar
2005 28' Safari
Port Orchard , Washington
Caulking is not designed to move, it is acrylic.
It is designed to be a CHEEP easy to use filler for stationary objects, (house).
The product type you would need is, "adhesive sealant."
And that is not silicone, or silicone 2.
Silicone will not adhere for an extended length of time.
Good quality adhesive sealants are usually xylene based and stink for days.
But they stick good, and stay flexible.
Silicone is co-hesive, it only sticks to itself,
and makes good low pressure gaskets.
But, requires some other mechanical fastern to stay in place.
Or, you could get some "gap filler." Backer rod is the correct term.
It is a foam rope, from 3/8" to 1" diameter. It fills the gap and leaves a convex surface.
So when you caulk the gap, the caulk takes on a concave shape,
which is the proper shape for a caulk of questionable adhesion.
Druupy is offline   Reply With Quote
Old 11-24-2007, 08:09 AM   #5
ScottW's Avatar
Hernando , Mississippi
Michelle:
Which gap are you referring to?
thanx
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 11-24-2007, 08:50 AM   #6
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
Michelle - Do you know if your stall is properly shored up from underneath? It sounds like there might be movement of the stall itself, with or without movement of the whole trailer.
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 11-24-2007, 08:53 AM   #7
Keymar , Maryland
That gap! no the other one.
Originally Posted by ScottW
Michelle:
thanx
Sorry,
the one between the upper and lower stall halfs.
Michelle TAC MT-0
Sarah, Snowball
Old 11-24-2007, 08:54 AM   #8
Keymar , Maryland
I don't know I will have to break out the mirrow and flash light and have a look.
Michelle TAC MT-0
Sarah, Snowball
Old 11-24-2007, 08:55 AM   #9
Keymar , Maryland
25,000 miles in less than two years. It is underway.
Michelle TAC MT-0
Sarah, Snowball
Old 11-24-2007, 08:56 AM   #10
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Michelle have you consided using PRC or Proseal or is the color all wrong.
Kip
Old 11-24-2007, 09:08 AM   #11
Keymar , Maryland
Kip
Well that would work but the color is all wrong and this stuff stinks for weeks! I even have a proseal gun just to make it easy to install. One down side I would never get that stuff out if I needed to.
I am hitting the road in about a hour so I will be off line until tomorrow.
Michelle TAC MT-0
Sarah, Snowball
Old 11-24-2007, 09:11 AM   #12
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
How about Vulkem? It seems to be the "Duck Tape" of the Airstream world and sticks to just about everything.
www.nesa.org
Air No. 6427
Old 11-24-2007, 09:37 AM   #13
Rollertoaster's Avatar
2007 25' Safari FB SE
Aptos , California
Hi Michelle,
You might try "Big Stretch" caulking. Water based, much easier to use than Vulkem or Sikaflex, several colors available.
Rollertoaster is offline   Reply With Quote
Old 11-24-2007, 10:26 AM   #14
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
Horrible stuff to use but butle rubber caulk stays like rubber for years, paint stores have it, as does Ace hardware
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
window gap nbka1bm Windows & Screens 11 11-22-2007 07:20 AM
Rear end gap Bobz Hog Repairing/Replacing Floor &/or Frame 8 11-15-2007 06:43 AM
tub/shower wall gap RevBec Sinks, Showers & Toilets 5 08-19-2007 06:59 PM
1975 Argosy MH 454 proper spark plug gap? cejohnsonjr Mechanics Corner - Engines, Transmission & More... 2 04-21-2006 10:17 PM
Gap between floor and shell tmcdougald Repairing/Replacing Floor &/or Frame 4 07-19-2005 05:44 PM
