06-21-2019, 03:33 PM
2014 23' International
Salt Lake City
, Utah
Cleaning sand off aluminum walls
Not really a restoration question but wondering if I could get some experienced advise on the best way to clean sand off the inside aluminum walls.
We had a window break in Lake Powell and a bunch of dry and moist sand blew inside. Everything was covered. I’ve cleaned most of it. Vacuumed the walls with a soft brush but there’s still sand on them.
When I tried wiping it down with a cotton rag and small amount of cleaning spray, it scratched the aluminum like sand paper.
Any advise? My only idea right now is to wipe down with a soaked micro fiber cloth. But I’d also like to know what cleaner if any is best for that. (Usually I use Lysol multi purpose surface cleaner).
06-21-2019, 04:20 PM
2012 Avenue Coach
Corpus Christi
Your problem is perplexing. I would have thought the light vacuuming with a soft brush to have done the trick. But when you said that failed, I suspected some kind of static charge was holding the grains of sand to the walls. But when you used a wet spray, I'd have thought that would have released the static bond. Sorry, I've got nothing.
06-21-2019, 05:02 PM
2015 25' FB Flying Cloud
Sandy
, Utah
This is going to be time consuming but I think I would roll up a towel at the base and then spray clean water on it starting at the top to loosen the sand. The aluminum is actually coated with a thin clear plastic like material which could be gently buffed if needed.
06-21-2019, 05:52 PM
2007 25' International CCD FB
Northridge
What about one of those super soft feather duster things to kinda sweep the sand down then vacuum up?
LilNomad
06-22-2019, 10:04 AM
CruiserGa
2004 25' Safari
Gainesville
, Georgia
Sticky lint roller?
06-22-2019, 10:14 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I would try one of the waterless cleaners they use for show cars. I use one called “Envy”. They sorta “float” the dirt off with a chemical layer under it. The Walbrize commonly used on Airstream exteriors May work also.
06-22-2019, 10:31 AM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
Cleaning sand
I would do this
Use our California duster to gently pick up the heavy stuff. Followed by a Automotive detail mist and light wipe with a fresh microfiber.
After that use Lemon Pledge with a soft Cotten towel or microfiber. Lemon Pledge is recommended by Airstream.
06-22-2019, 12:28 PM
2016 26' Flying Cloud
2016 20' Flying Cloud
St Petersburg
I'd try masking tape. It's known for picking up small particles without leaving adhesive behind. 🤔
2016 Flying Cloud, 26U! REX
2018 Tundra Limited, Attitude Black, The Princess Behemoth!
2016 Flying Cloud 20, REX, gone but never forgotten.
06-22-2019, 12:34 PM
2007 22' International CCD
Corona
Or a car detailing clay bar
06-25-2019, 09:31 AM
2019 25' International
Washington
, Washington, D.C.
Or duct tape.
