Old 07-30-2014, 01:47 PM   #1
1991 35' Airstream 350
Martinez , California
Classic 350 GM Chassis 454 fuel pump
I need to replace the fuel pump. Any help out there? Are there two? one in tank and one chassis/frame mounted?
larryschwarm is offline   Reply With Quote
Old 07-30-2014, 02:21 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
On an '87 345 there were two. One mounted between the tank and the air volume tank, and the other on the engine.
There was also a large filter/regulator just forward of the entrance door mounted on the frame.
Be aware there may be dry rot in the rubber lines, this would cause air to be pulled into the pump displacing the gas. Had a large problem with the Onan generator because of dry rot in the genny suction line.
Do several searches asking your question in different manners. Many GM chassis questions were discussed in the early to mid 2000's. All of the answers to questions are as good now as they were then.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
INFO: Fuel Pump - 86 Chevy 454 MrJ Mechanics Corner - Engines, Transmission & More... 0 05-14-2012 11:37 AM
454 fuel pump crazeevw Mechanics Corner - Engines, Transmission & More... 12 12-15-2011 06:07 PM
1992 Airstream Classic 350 LE Orig. Owner 454 Chevrolet eBay Watch Airstreams on eBay 0 03-11-2011 05:40 PM
Airstream Classic 350 LE Motor Home 1992 Orig. Owner SAirstream Classic 350 LE Motor eBay Watch Airstreams on eBay 0 11-28-2010 10:00 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
