Old 11-04-2018, 12:02 PM   #1
2017 30' Flying Cloud
medford , OR
City water valve leak
Has anybody had a problem with the city water valve and the pressure regulator leaking? It only does it with the hot water heater turned on. Im on my second, soon to be 3rd one. The first one dripped a lot, this one is a slow drip. You can hopefully see it on bottom of valve.
bvrs2020 is offline   Reply With Quote
Old 11-04-2018, 02:23 PM   #2
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
There is supposed to be a flex pipe connected to it per the mfr instructions that I o rained buying my first replacement. My airstream has fixed piping and it's now leaked 2x because I never added the flex pipe. I'm investigating flex options now. Hate to get in there to mess with it because the space is so tight in my unit.
SCOTTinNJ is offline   Reply With Quote
Old 11-04-2018, 02:42 PM   #3
medford , OR
Air stream is replacing both of mine. 1st one was under warrenty. The valve is connected to pex fitting that screws in. I sent a video to airstream with the 1st one and they didnt say anything about the connection. From mumy understanding pex is flexible.
Old 11-04-2018, 03:54 PM   #4
blufishin's Avatar
2015 25' FB Flying Cloud
Wilmington , North Carolina
Yes, I've had this issue since I purchased our trailer. It only leaks when I turn on the hot water heater as the water expands. I remember reading somewhere (owners manual maybe?) that the excessive water pressure can be relieved by opening a water faucet briefly as the water heats up. When I can remember to do this it does not leak.
Jere Freeman
2015 FC 25FB w/ Hensley
2017 GMC Denali HD 6.6L DuraMax
blufishin is offline   Reply With Quote
Old 11-04-2018, 04:15 PM   #5
2014 30' FB FC Bunk
A long run of pex is somewhat flexible. But mine is off maybe a 2" tee. It's going nowhere. When that valve fails you can see how it's being pulled.Click image for larger version
ID:	327016Click image for larger version
ID:	327017Click image for larger version
Old 11-04-2018, 04:33 PM   #6
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
The city water inlet/pressure regulator will leak if the interior water pressure gets too high. Sometimes you can fix it by snugging down the four screws on the back of the unit.
SSquared is offline   Reply With Quote
Old 11-05-2018, 10:48 AM   #7
Lynn
Beaverton , Oregon
Inlet water valve
My fresh water inlet valve started to leak on the inside last year while on the road. I thought the valve was faulty, couldn't find a replacement in Pahrump, NV so I took it apart, cleaned it and greased the inner valve parts with plumbers vaseline jelly. Put it back together, works great ever since.Found out the internal pressure valve was stuck causing the water to leak inside the trailer.
aliner is offline   Reply With Quote
Old 11-05-2018, 01:15 PM   #8
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi bvrs2020,*
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 11-05-2018, 04:35 PM   #9
Trempealeau , Wisconsin
City water inlet leak
Happened to us last year. Took the city water inlet valve apart and tightened the four screws on the back. End of problem. Also purchased a spare on Amazon.
twrastall is offline   Reply With Quote
Old 11-05-2018, 08:04 PM   #10
waltb's Avatar
2014 25' Flying Cloud
San Luis Obispo , California
Send a message via AIM to waltb Send a message via Skype™ to waltb
I tightened the four screws and added a flexible water line to eliminate the pressure from the pex line movement.
[ATTACH]327150
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
waltb is offline   Reply With Quote
Old 11-05-2018, 10:27 PM   #11
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It seems to me that Airstream would consider discontinuing use of a pressure regulator since moving to pex.
In my build that uses pex and residential fixtures, I havenít used a pressure regulator for almost six years now.
That being the case, my pressure regulator can never leak or cause me problems. Sometimes maybe simpler is better.
Just my take though!
J. Morgan is online now   Reply With Quote
Old 11-05-2018, 10:49 PM   #12
medford , OR
Thanks for all the suggestions. I'll take it out and do somw checking and grease the insides and see what happens before i preplace with new one.
Appreciate all the help.
Old 01-13-2019, 03:29 PM   #13
2013 28' Flying Cloud
Penn Yan , New York
Regulator leak
I had noticed water dripping at the rear of the left wheel well. I know there is a condensate drain at the front.
Checked the regulator and sure enough when the hot water was turned on it would leak.
In homes there is an expansion tank but not in the Airstream.
I would think you could get a small one that would fit.
I changed the regulator and so far no leaks.
delrossa is offline   Reply With Quote
Water leak when hooked up to city water. Please help :) jck_dmb General Repair Forum 27 07-17-2018 08:04 AM
Valve repairs and city service leak ?s Schess16 General Repair Forum 5 06-28-2018 04:39 PM
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 03:45 AM
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
