Old 05-09-2013, 05:09 PM   #1
jornvango's Avatar
City water hookup leaking
Today, when we arrived at the next campsite (we're traveling), the city water hookup on the AS decided to start leaking heavily. So much so that I decided to simply fill up the water tank and use that, as opposed to leave the city water hooked up.
What are the options for repair? Replace the entire small hookup thing?
Thanks!
jornvango is offline   Reply With Quote
Old 05-09-2013, 05:20 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
First, replace the gasket in the bib,to make sure it isn't that. Then check the hose to make sure the end isn't damaged.
Old 05-10-2013, 11:35 AM   #3
jornvango's Avatar
Where can I find some instructions? When I unscrew the 4 screws holding the metal plate in place, I cannot take the assembly out since the opening is too small.
Old 08-24-2013, 12:13 PM   #4
jornvango's Avatar
This issue has resolved itself. Seems like something was wrong at the campground.
