Old 02-16-2015, 11:51 AM   #1
Cardinal283's Avatar
Dallas , Texas
Citristrip
I see a lot of people talking about and recommending Citristrip. Is that because it's more environmentally friendly, it doesn't have the harsh fumes like tradition strippers, other strippers interact with the aluminum, or because it out performs other strippers?
Cardinal283 is offline   Reply With Quote
Old 02-16-2015, 12:19 PM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
In my experience it performs well removing zolatone from aluminum with no apparent damage to the underlying metal. Lack of toxic fumes was a huge plus given that I was working in a tightly enclosed space. Make sure you wear good gloves though. You do not want this stuff sitting on your skin.
BambiTex is offline   Reply With Quote
Old 02-16-2015, 12:45 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
I use it for small jobs for it’s environmental impact. Great for vents, moldings, window frames, ect. Works well on the aluminum and pot metal castings. Soap and water cleanup makes it easy to work with.
For removing large sections of clearcoat I find it less than ideal. When warm it tends to run and drip a lot on the sides of the trailer. It usually takes two overnight applications and works better when covered with plastic.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Using Citristrip to take off clearcoat Jim in Pima Clearcoat, Exterior Paint & Trim 7 04-28-2014 09:19 PM
Remove water-spots from removALL/Citristrip DustDom Our Community 3 06-21-2012 07:14 PM
Any problem with using Citristrip? glacierrunne Cleaning, Stripping & Polishing 1 02-01-2010 05:14 PM
Tried citristrip and aircraft remover? evelitalian Cleaning, Stripping & Polishing 15 03-22-2008 06:23 PM
