Old 03-22-2012, 12:30 PM   #1
1996 33' Land Yacht
tucson , Arizona
Chevy 454 engine rebuild
I am in the process of needing my engine rebuilt, AGAIN. Anyone know of a company that rebuilds Chevy 454 engines especially for motor homes?
Thanks.
pacer is offline   Reply With Quote
Old 03-22-2012, 01:00 PM   #2
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Have you thought of a Jasper re-manufactured engine? Several members here have Jasper engines and have been satisfied. They also have a warranty. You can use their website to find an authorized dealer. Also, their warranty is nationwide.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 03-22-2012, 02:13 PM   #3
1965 22' Safari
East Islip , New York
Pretty much any engine shop with a guy in his 40's or older will be able to rebuild a 454. If you know any off-road groups in the area they may be the best folks to ask for local recommendations. These guys will have similar requirements to you in regards to torque curves and powerband. If you ask somebody who enjoys old musclecars, they generally build for different conditions, and may not give applicable advice.
If you're looking for long life, make sure to add in a crank scraper and/or, windage tray and have it bored using a torque plate. I wouldn't go as far as balanced/blueprinted for the application though, that's expensive overkill. Make sure to specify the fuel octane you want to use as well, since the pistons are based off your compression needs, and that's mostly based on the fuel used.
A good engine guy will ask you a lot of questions about your intended usage.
-Hans
HHaase is offline   Reply With Quote
Old 03-22-2012, 03:10 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
My approach to rebuilding has been to purchase pre-assembled long blocks. The costs are lower and more certain and there's a warranty. I work with my local NAPA who gets their long blocks from a rebuilder in Wisconsin. It's a production environment there and they build dozens of engines a day.
Shower wall rebuild Joebanjo Sinks, Showers & Toilets 9 03-03-2013 11:09 AM
Argosy 20' MH 350 Versus 454 MPG? ViewRVs Argosy Motorhomes 12 03-22-2012 11:58 AM
Skyliner antenna rebuild Flynavy Audio, Video & TV 17 03-12-2012 01:46 PM
1977 Argosy 24' MH with Chevy 350? ViewRVs Argosy Motorhomes 3 03-08-2012 09:42 AM
2007 Airstream Interstate 22' Front Lounge Mercedes Benz Diesel Engine Class B eBay Watch Airstreams on eBay 0 02-24-2012 12:10 PM
