Old 02-06-2013, 06:15 AM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Changing tires on the AS
If I am changing a tire - where do I place the jack and whats the best procedure?
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 02-06-2013, 06:28 AM   #2
Goal15's Avatar
Dallas , Texas
Varying schools of thought
Changing tires on the AS?
First the obligatory invitation to use the search function to find previous threads on this. A wealth of information.
Some people prefer to use a wooden ramp made of graduated lengths of 2x10 to lift that side of the trailer and thereby leaving the tire you want to change suspended off the ground while the other tire on that side sits elevated on the ramp.
I use my Tundra's bottle jack under the steel support that is right behind the tires. Make sure it's the steel piece that is a channeled beam that you can see some 3-4 inches behind the tires as you face the trailer.
I make sure my trailer is chocked with my locking chocks before i do this jacking and only jack just enough to get the tires off the ground.
There is pretty much general agreement that if you are going to use a jack to jack up the trailer, this is the only spot that you should really use. There are a couple of jack points under each corner of the trailer but that seems to be a place that you really need to hit exactly the right spot or you risk playing havoc with the belly pan.
Im sure others will weigh in, but here's a quick answer. And the obvious, don't forget to loosen the lugs BEFORE you jack it up, much easier.
Good luck
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 02-06-2013, 06:28 AM   #3
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Very easy and quick to accomplish. Assuming you have twin axles, roll your good tire on the flat tire side up onto your leveling blocks until the flat is well clear and change away!
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 02-06-2013, 07:15 AM   #4
2003 25' Safari
Riverside , California
Indeed the quickest and safest method.
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 02-06-2013, 07:25 AM   #5
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
If you have a tandum axle, use the chocks or get one of these:
http://www.genuinehotrod.com/itemgroup/trailer-aid
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 02-06-2013, 07:35 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Tip for the futureÖ
Once you do figure out the best point to put the jack, mark that point (on each side of the trailer) with a small piece of reflective tape. That way, you never have to wonder again if you've got it right, even if you're changing the tire at night by flashlight next time; just put the jack on the tape and you're good.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-06-2013, 07:42 AM   #7
2008 16' Safari
Destrehan , Louisiana
I've got the single axel and just use a floor jack.
dlb435 is offline   Reply With Quote
Old 02-06-2013, 07:55 AM   #8
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Ramps are the quickest if on the road and/or hitched.....
Safest jack point....
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 02-17-2013, 03:14 AM   #9
1970 27' Overlander
Thanks to all (especially you Robert C- my hero)...I have ordered new tires and they are on their way. Since we are still in February, and the skirting is still wrapped around. So I do have a chock device and plan to use the roll it forward and up onto method. The two cats that stay under there are going to have to find another sleeping area after I take the skirting down. Once the skirting is down, it will stay down and stacked to the side, to later transport. I do have access to a good floor jack too...I was just thinking the floor jack might be quicker. Just don't want to compromise the frame of the Airstream.
Old 02-17-2013, 07:53 AM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Use the ramps. It is safer all the way around. Don't forget to break the lug nuts loose before raising the tire. If you use a ramp on each side, it makes quick work of the job.
TG Twinkie is online now   Reply With Quote
