Old 01-09-2014, 08:48 PM   #1
1988 32' Excella
Radcliff , Kentucky
Changing out hubs on 1988 25' Excella
I have a set of fairly new complete hubs I removed from my other Airstream when I put on disc hyd. brakes. I am refurbishing my 25' 1988 excella and plan to put the better hubs on it. Is there any thing I should know outside of remove and replace in the same order? The ones I plan to install are about 2 yrs. old and are like new.
cbjohn is offline   Reply With Quote
Old 01-10-2014, 08:01 AM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Hey John. Will you be replacing the bearings at the same time ( recommended ). If so you must also remove and install new bearing races in the new hubs. If you go this route I would advise getting a good set of Timken ( or other American made ) bearings and matched races and, of course, new seals while you're at it. A little extra work but since you're going to go this far you won't be sorry. Go for it.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-10-2014, 10:01 AM   #3
1972 Travelux Princess 25
Cobourg , Ontario
If the bearings are like new and show no wear they can be reused. I would replace the grease seal as a matter of course, whenever repacking the bearings.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 01-11-2014, 10:26 AM   #4
Dean E's Avatar
1989 32' Land Yacht
Oakton , Virginia
After cleaning the bearings in solvent, visually inspect the outer races and bearing assemblies' surfaces under a good light for scoring/roughness, cracks, and discoloration. Discoloration indicates high heat, and weakened parts. Look for a color range from straw to blue.
With new bearings, I also prefer premium brands, which are packaged against dust--unlike those in open, bulk bins at RV stores.
I get dealer prices on bearings by asking the parts clerk to write it up for Dean's Garage, and telling him or her that I will pay the state sales tax.
Sent from my SPH-L720 using Airstream Forums mobile app
Dean E is offline   Reply With Quote
Old 01-11-2014, 12:07 PM   #5
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Originally Posted by cbjohn View Post
I have a set of fairly new complete hubs I removed from my other Airstream when I put on disc hyd. brakes. .
John
Welcome to Airforums.
I would really like to hear some details about your disc brake install. Are you glad that you did it? What components did you use and what was your source?
Thanks in advance, Dan
Axles, brakes, hubs, tires...all out of my comfort zone cford Axles 2 06-24-2012 12:34 AM
changing 10" hubs to 12" Orlop Wheels, Hubs & Bearings 6 05-14-2012 06:09 AM
Changing out faucets- what size copper piping? charlie tuna Fresh Water Systems 10 08-22-2006 11:02 AM
Changing the Twins out Fun-Lovin General Interior Topics 5 09-25-2003 02:47 PM
Changing out the Black water tank AccessMaster Airstream Motorhome Forums 8 08-30-2003 08:03 AM
