Old 09-10-2017, 09:33 PM   #15
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
Mixed emotions about that. You see some pretty shoddy trailers rolling around Houston area, as I'm sure other areas do. Glad I don't have to bother with the Airstream, but can't help but think this change had public safety in mind...
DaveMc is offline   Reply With Quote
Old 09-10-2017, 09:45 PM   #16
2010 27' FB Classic
N/A , Texas
This is good news, we are finally getting a break.
PeterH, Thanks for posting about the new law.
Old 09-11-2017, 09:00 AM   #17
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Don't know about x, but in CO "SBxxxx" would be a bill still in the state senate, not yet a state law.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 09-11-2017, 09:12 AM   #18
1987 25' Sovereign
Not "x" -- meant to type "TX" but my keyboard is boogered. Anyhow, agree it would be a good thing -- but are you sure it's passed/signed?
Dan & Liz H
Old 09-11-2017, 12:38 PM   #19
2009 25' FB International
Corpus Christi , Texas
Our 25' international fb has a empty weight of 5500 lbs plus the carrying capacity if 1800 gives our trailer a gross weight of 7300 lbs.
From the State of TX website:
Trailers
Registration is required for all non-farm trailers operating on public highways. Registration and titling requirements vary according to trailer type and weight. Most utility trailers fall into two categories: Manufactured (built by a trailer manufacturer) or homemade (built by an individual in their garage or shop). In addition, trailers are categorized by gross weights (the trailer weight plus the weight it can carry) under and over 4,000 lbs.
Trailers with a gross weight exceeding 7,500 lbs. must pass an annual safety inspection.
In some cases, you may be asked to provide additional information such as:
  • Weight Certificate, and/or
  • Photograph of trailer.
For information about all required documentation and fees, contact your county tax assessor-collector office.
67shellback is offline   Reply With Quote
Old 09-11-2017, 02:40 PM   #20
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Be sure and check the data plate and registration for the correct gross vehicle weight. Sometimes the wrong info gets documented. Texas registration fees are base on GVW stated on the tittle.
guskmg
Old 09-11-2017, 03:44 PM   #21
PammieSue's Avatar
1988 32.5' Airstream 325
Vista , California
I don't suppose our 1988 325 Classic Moho fits in this category. It and our jeep are both registered in Chris's hometown.
Dysfunctional Veteran- does not always play well with others. 19 a day is 19 TOO MANY.
(19 recently revised from 20, revised from 23, revised from 22. Even the VA is a work in process)
PammieSue is offline   Reply With Quote
Old 09-11-2017, 05:55 PM   #22
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Originally Posted by PeterH-Airstreamer View Post
New Legislation
Senate Bill 1001
Effective Sept. 1, 2017
SB 1001 changes the actual gross weight or registered gross weight for a trailer, semitrailer, pole trailer, or mobile home from 4,500 pounds or less to 7,500 pounds or less to be exempt from vehicle inspection.
Used to be 4500 pounds or less
That's great, because where I live, the inspection was a joke.....just checked
to see if the rear lights worked.
banderabob is offline   Reply With Quote
Old 09-11-2017, 10:07 PM   #23
2017 25' Flying Cloud
the woodlands , Texas
I got jipped
Bought a new 25' FC in December 2017 and went to register it in Texas since it was an out of state purchase. I was told I needed an "inspection". I explained it was a trailer without a motor and was told, I need an inspection. So took my baby who was nice and clean out in the rain and mud to a local service station where they looked at the lights, commented about the hitch (ProPride) and said what a nice trailer it was. I will have to look and see what weight is on the title, so I can skip that next year, I hope. It was in Montgomery County.
Leslieotr is offline   Reply With Quote
Old 09-11-2017, 10:37 PM   #24
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Nice, Texas is going to be our new domicile state.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 09-12-2017, 06:37 AM   #25
2012 30' International
Livingston , Texas
I cannot find official documentation but when went to a service station to ask about how to get my AS safety inspected last Spring, I was told by the inspector that if you have a trailer semi-permanently set up and can't pull it out easily, an inspection is possible with the AS paperwork only. It worked for me.
glenrms is offline   Reply With Quote
Old 09-12-2017, 07:09 AM   #26
Martee's Avatar
Waco , Texas
I feel the same way. Here in Waco; I have seen some mighty poor trailers used daily by contractors. Cracked frames, loose floorboards; parts rusting off the trailer. I would have simply amended the law to exclude any trailers 5 years old and younger from inspection.
Martee is offline   Reply With Quote
Old 09-12-2017, 09:14 AM   #27
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
The charge for trailer inspection is only $7. Inspections stations will not spend much time inspecting anything on your trailer. Probably ask to turn on the lights and they will give a glance at the tires and kick them and then sign off.
My Classic 25fb has an 8000lb GVWR. If we decide to domicile in Texas it can't be that hard to find an inspection station to do the trailer.
Kelvin
KJRitchie is online now   Reply With Quote
Old 09-12-2017, 12:08 PM   #28
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
My 1997 30' registered weight is 7200, you may want to check yours, Bruce
There is a difference between REGISTERED weight and the GVWR on the data plate. My GVWR is 8300-but I COULD register it at 6700 or such.
You ever get pulled over and checked, there will be a hurt coming. For $14.50-no thank you. I'll register mine as tagged and get it inspected.
It's more of a pain to hook up and drag to the station than it is to have inspected. I try to coincide with a camping trip when I am hooked up anyway.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
He is your friend, your partner, your defender, your dog. You owe it to him to be worthy of such devotion.
bwoodtx is offline   Reply With Quote
Changes in Attitude Changes in Latitude beachbouy Off Topic Forum 6 09-03-2016 08:57 AM
Texas travel trailer inspection neerseer Title, VIN & Registration 13 07-25-2016 11:08 PM
Annual Inspection changes (NY) Bummer 3campers Airstream Lifestyle 3 05-18-2014 06:51 PM
Black water holding tank changes for using trailer as stationary home/external septic bol-gordon All Argosy Trailers 3 05-20-2009 08:34 AM
