Old 04-20-2015, 12:33 PM   #1
1989 25' Excella
Glenwood Springs , Colorado
Ceiling Pop Rivets
I need to replace a few rivets in the ceiling panels of my '89 Excella
What size should I use?
Thanks mczajk
mczajk is offline   Reply With Quote
Old 04-20-2015, 01:58 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
1/8 od is common size. Sometimes the holes get egg shaped before the rivets pop and then you have to use the next size up. If you are having too many pops, it is likely that your axles are shot or you are abusing the trailer with: too stiff suspension on your truck or your road/speed is too rough.
Old 04-20-2015, 05:30 PM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
You can get the OEM rivets (colored white) from JC. They come in packages of 25 (as I recall). Just call 937-596-6111 and use the option for service/store/tour - Amy will gladly send them out to you.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Pop rivets staying on bit during removal bennyg Ribs, Skins & Rivets 14 11-20-2010 10:11 AM
Closed End Pop Rivets vhord Ribs, Skins & Rivets 18 05-29-2010 10:04 PM
Pop Rivets For Bumper tgh97531 Ribs, Skins & Rivets 2 01-22-2010 06:59 AM
