Old 05-27-2012, 07:09 AM   #1
Rubyslipper's Avatar
1995 30' Limited
Warsaw , Missouri
Ceiling coming down!!!
Someone help quick...! The vinyl is coming down inside our 1995 Limited! what is the best adhesive to use to get it back up. Theres several products out there for Headliners but all say they have acetone and Im afraid it will eat into the layer of insulation.
Rubyslipper is offline   Reply With Quote
Old 05-27-2012, 07:26 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
This is a well discussed problem here on the Forums. I had it on a 93. From the experts.....no adhesive will work without a complete pull out and surface cleanup. That means removal of the interior to get at the headliner. There are other methods using screws...check it out in the search function.
Old 05-27-2012, 07:41 AM   #3
1995 30' Limited
Warsaw , Missouri
In a panic....leaving on a big campout! Not about to use screws on it! SOmeone mentioned a waterbased adhesive...that would temp repair.
I realize it will have to come down and be replaced but thats time consuming as well as costly.
Old 05-27-2012, 09:10 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The urethane foam that is used as padding behind the vinyl is degrading as well as the adhesive. You would need to replace both to make the fix work. The solution I suggest is to mechanically hold the vinyl in place with bows from below. Done properly, it looks good and works with much less expense of time or money.
