Old 06-23-2012, 05:09 PM   #1
R n B
King O D Road's Avatar
1965 17' Caravel
1961 24' Tradewind
Ephrata , Washington
Cast emblem repair
I broke the L off of the cast caravel name on my 65. I finally found it in the shop where the buffer had repositioned it to. I purchased "Super Alloy 1" from www.muggyweld.com to see if I could save the emblem. I was impressed with the results. The filler material even flowed to the back side and around the attach post. Follow their directions EXACTLY. Good Luck. Roger
ID:	161658   Click image for larger version
ID:	161660   Click image for larger version
King O D Road is offline   Reply With Quote
Old 06-23-2012, 08:42 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Good job!
Dave
Old 06-23-2012, 09:42 PM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Looks like new Roger, glad it worked out!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 06-26-2012, 06:29 PM   #4
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Glad to see you got the "L" out of the shop and back where it belongs.
Great job, look forward to seeing it in person at Wenatchee event.
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 06-27-2012, 07:40 AM   #5
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
This is great! I was looking through my miscellaneous parts the other day from the previous owner of my caravel. I found the missing "L" on mine. I thought it was long gone until I see a wadded up paper towel in the bin with other parts. I opened the paper towel to find my "L". I wasn't sure how I could repair it, but this looks like the answer! So, did you use a Butane torch. I have one of those, but do not have an acetylene welders torch. Will that work? Is that what you used?
Another question is if this same method might work to fix a cracked door frame?
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 06-27-2012, 09:32 AM   #6
R n B
1965 17' Caravel
1961 24' Tradewind
I used a propane torch to do mine. Just do as they say, clean area very well, keep it moving and watch the color of the flux and don't put the rod in the flame. I found a old piece of pot metal to try it on first. I don't know if it would work for your door frame. I took a die grinder and beveled the edge of mine and took it to a welding shop where they had a aluminum wire feed welder large enough to weld that thick of metal and it was welded in place. Sprayed water around the weld area with a hand spray bottle and all turned out excellent.
