Old 09-29-2016, 02:52 PM   #1
2009 27' FB Classic
Cincinnnati , Ohio
Carpet damp under left side twin bed.
I was looking for our winter blankets which are usually stored under our twin beds in our 2009 Classic. I could not find them but noticed the plastic looked a little funny. I took a scissors to it and sure enough the carpet underneath was damp. Is this moisture coming from the outside storage unit?
KathleenBenk is offline   Reply With Quote
Old 09-29-2016, 03:43 PM   #2
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
It could be the outside storage compartment, the back bumper, window seal or leak around lights. I suggest you take it to a dealer capable of using a blower to pressurize the interior and spraying the outside with soapy water to observe where bubbles are occurring.
Have you checked to see if the flooring is soft underneath? If it is not, you may have found the problem before sub-floor damage has occurred.
Good Luck.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 09-29-2016, 04:43 PM   #3
1993 25' Excella
CLeveland , Ohio
One other idea: Reseal rivets and the leak may stop. I had the same issue.
Akronguy is offline   Reply With Quote
Old 09-29-2016, 07:24 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I recently solved a minor leak under one of my twins. The storage access door hinge is riveted to the compartment frame. The rivets are outside the seal that keeps water out. Rain was going in the rivet heads. Capt. Tolleys took care of my problem.
CRH is offline   Reply With Quote
Do you use Damp Rid for winter storage? MN Jeff Winterizing, Storage, Carports & Covers 13 10-26-2015 09:32 PM
Left turn and left brake lights not working Morgan guy Lights - Interior & Exterior 9 02-01-2015 07:08 AM
damp/wet carpet dhe9 General Repair Forum 13 12-03-2007 09:01 PM
uneasy airstreamer damp and despondent Annemac 2006 Safari SE 12 10-16-2007 02:27 PM
'05 Safari Flooring damp area above spare tire. tpi 2005 Safari 0 05-27-2007 04:38 PM
