Old 02-11-2012, 09:51 PM   #1
san francisco , san francisco
Can't find the 12v fuse bus...
manufacture date 11-1977 28' Ambassador.
Can anyone tel me where to find the 12v fuse bus? I have owned several non-AS trailers over the years and know my way around the systems. However I was totally stumped today looking for the 12v panel.
Dan
lilduckidan is offline   Reply With Quote
Old 02-11-2012, 09:59 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
On my 1979 Safari, the fuses are between the batteries on the front wall.
Bill
Dan
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Old 02-11-2012, 10:15 PM   #3
azflycaster's Avatar
1975 25' Tradewind
Phoenix , Arizona
Images: 67
On my 75 TW the battery is in the rear and the converter and fuse panel are close by. Your battery(s) is in the front and the panel should be up front where Bill has suggested.
Richard
Charter Member Four Corners Unit
Old 02-11-2012, 10:38 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Here's a photo from my 1983 Excella. The gaucho has been removed for replacing the Univolt.
You can see the fuse panel, with its cover removed, above the Univolt between the battery boxes just under the front window.
Vaughan
vswingfield is online now   Reply With Quote
Old 02-12-2012, 09:31 PM   #5
1974 27' Overlander
Twisp , Washington
On ours, the fuse panel is INSIDE the Univolt housing, which was a major PITA, since the Univolt was tucked in under the tub. Of course, ours is 4 years older than yours. Good luck.
Dave
daved20319 is offline   Reply With Quote
Old 02-13-2012, 12:35 AM   #6
Mexray's Avatar
1978 29' Ambassador
Morada , California
Our 78, 28ft Ambassador's fuse panel is the same as the photo above...
We have the gaucho on the 'side', not across the front, and the access is through the cabinet that spans the width up front below the fwd windows...and it's a pain to get too - on hands and knees...
I guess the 'design staff' never had to make service calls on the fuses or their wires - otherwise they may have changed the location to a more convenient location!
Ray & Pat near Lodi, CA
Can not blow my horn la nomade Classic Motorhomes 22 05-16-2012 04:52 AM
May The Airstream Gods Forgive Me wasagachris Off Topic Forum 82 03-14-2012 06:16 PM
Duo-Therm CCC bad out of the box? scarylarry Furnaces, Heaters, Fireplaces & Air Conditioning 10 02-27-2012 07:02 AM
Help-Sagging in the rear Frankiefiveo Repairing/Replacing Floor &/or Frame 10 02-17-2012 06:10 AM
