Originally Posted by Ky76Argosy
I see others have water leaks into interior at wheel wells, so can yo clean, caulk and seal with commercial undercoat, ziebart, or rhino liner type products? Or why not? Thanks
On my '65 Overlander renovation, we plan on sealing underside of metal fender wells with some type of rubberized liner. I have already sealed the metal fender wells against the floor on the inside with Tempro sealant. First, I treated the wood with a deep penetrating epoxy that soaks completely through the wood to turn it into a piece of resin board four inches out from fender well.
I have already thrown away the ABS plastic which were broken and unusable. I do not plan on replacing these and instead am going to spray some sealant, line with 6mil plastic, seal with spray sealant again and then start my wood work from there.
