Old 08-30-2014, 11:54 AM   #1
jvcolaizzi's Avatar
2016 30' Classic
Park City, Utah , Utah
Can I stand on roof to check for leak???
I have a 25 FB International and during raining periods I have water leaking from around my bedroom vent fans. I want to get on top to take a look and caulk if necessary.
John
jvcolaizzi is offline   Reply With Quote
Old 08-30-2014, 11:56 AM   #2
1986 31' Sovereign
Miami , Florida
Try to stay on the seams. We all need to get up there now and then.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 08-30-2014, 12:37 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
One day I will take pics... I have non skid on roof then Place wood planks to straddle the "rib line rivets" and ribs, now to stern direction. Add as many board as necessary to support. NEVER step between ribs....unless you have boards to spread your weight.
I use 2x8 pine board planking....
Now, if you weigh as much as Tinkerbell, just step on ribs without planking.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-30-2014, 12:45 PM   #4
John
Airstream, many years ago, had 30 employees standing on the roof of a 30 trailer, without any damage or water leaks.
Walking slowly on the roof hurts nothing, just don't jump up and down.
Old 08-30-2014, 01:56 PM   #5
2008 27' Safari FB SE
Danville , California
I have personal knowledge, stay away from the end caps.
tkb2041 is offline   Reply With Quote
Old 08-30-2014, 01:58 PM   #6
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I've watched average sized men walk on mine at the AS dealer. They just walk on the ribs, Me, I'm too chicken. I like cwf's suggestion though. Besides not walking between the ribs, don't walk or even lean on the end caps either.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 08-30-2014, 02:44 PM   #7
1981 31' Excella II
New Market , Alabama
Mine holds up my 270 lbs without an issue. Not wise to stand on a wet roof unless it is coated. That would be a great way to end up in the ER.
Remove all old caulk and re caulk. If the vent is plastic it will eventually crack if it has not already. Caulk all seams and screw heads.
Perry
Old 08-30-2014, 04:37 PM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
On a factory tour, we were told to access the roof from the awning side. The awning will catch you if you misstep.
2012 Dodge Durango Hemi/AWD
Old 08-30-2014, 10:02 PM   #9
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
And at AS factory service the tech ALWAYS uses a safety harness when working on the roof. Better safe than sorry!
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 08-31-2014, 06:45 AM   #10
1981 31' Excella II
What you going to attach a harness to?
Perry
Old 08-31-2014, 06:59 AM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Slipping/falling from the roof looks quite possible to me. Only work I have done there is to install a Maxx-Air vent on the fan between the aft solar panels and was able to work on ladders from either side.
Doug and Cheryl
Old 08-31-2014, 08:18 AM   #12
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I have never seen the need to walk on the roof, I usually sit on my can or up on my knees to accomplish my rooftop tasks.
If I am working on the a/c, I climb up next to the a /c, if I am working on the vents, I climb up by the vents...
Walking on the roof is an unnecessary risk.
Old 08-31-2014, 08:25 AM   #13
dougandlori's Avatar
2004 28' Classic
Fresno , California
I used a piece of plywood about 18 inches wide and 6 feet long. It is long enough to span a number of ribs and distributes the weight. I recently re-caulked my roof this way with no problems. The job is done and I don’t look forward to another trip to the roof.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 08-31-2014, 03:11 PM   #14
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Perry
Last week I had a roofer quote on reshingling my roof. He mentioned to me that the Workplace Safety Board requires roofers (as well as people working on the roofs of RV's) to wear a safety harness; failure to do so voids their insurance. This coupled with a thread in the motor-home section of an airstreamer who fell off the roof of his motor-home and endured compound fractures tells me that safety is most important.
In answer to your question - look for a place under a tree or near a pole to which you can attach the harness. The harness works like a car belt and catches you if you slip.
Personally, I don't crawl up on any roof any more.
VE3JDZ
AIR 12148
Can your airstream roof stand up to the snow? wacnstac Roof 5 10-01-2010 05:05 AM
Can you stand another NG? Larry in MO Member Introductions 6 08-26-2008 08:54 PM
Can you stand another newbie?? TinLizzie Member Introductions 16 02-02-2006 05:59 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
