Old 07-21-2015, 02:24 PM   #1
jdlimages's Avatar
1961 22' Flying Cloud
Oklahoma City , Oklahoma
Can I run my AC with only 20 Amp breaker?
I want to take my 61 Flying Cloud to my friends house for a visit. He has a 200 amp panel but only 20 amp available breakers. I have an adapter plug that turns the 30 amp plug into a standard household plug. Is this a OK to just run my AC? I don't want to start a fire or fry my AC. Any thoughts or experiences with this? Thanks.
jdlimages is offline   Reply With Quote
Old 07-21-2015, 02:33 PM   #2
SteveH's Avatar
Common Sense , Texas
If you have one of the smaller A/C units, yes, but you can't run anything else at the same time.
Regards,
Steve
Old 07-21-2015, 02:38 PM   #3
dznf0g's Avatar
Oswego , Illinois
My 13.5K btu unit will run on a 20 amp circuit without anything else running at the same time. BUT, the A/C seem to be a bit slow on compressor startup. I ran it like that a few times, but never felt really good about it. I now have 2 30 amp dedicated circuits. One on the driveway side of the house and one on at the parking pad for the AS. (new this spring)
-Rich-
Old 07-21-2015, 02:39 PM   #4
2016 30' Classic
Erie , Colorado
Running probably. Starting maybe. And that's when the damage might occur. Hard to answer your question without knowing the Make/Model/Size of the AC unit. If it is original it probably isn't as efficient as a new one. Best way to tell is to measure the amps on the AC circuit to see what they do as it starts and then runs. An AC Clamp meter would do it well. You would need to find the power wire for the AC.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 07-21-2015, 02:56 PM   #5
1974 Argosy 20
Kooskia , Idaho
Assuming nothing much else is on (water heater, refrigerator on electric) and you are not running it from a long extension cord, you will be just fine, both starting and running.
Extension cords and their common small sizes and poor plugs are a no no.
Old 07-21-2015, 03:46 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My 11,000 btu cooler will run on a 15 amp circuit all day and all night.
Assuming a 13,500 btu cooler, your A/C will run on a 20 amp circuit 24/7 with about (at least) 5 amps (600 watts) to spare to run anything else.
To the greatest extent, so long as you don't trip a breaker, your a/c will run just as well on a 20 amp circuit as it will a 30 amp circuit assuming you don't use an undersize extension cord to power your trailer.
Old 07-21-2015, 04:10 PM   #7
Mission , Texas
After getting the new to us 75 Overlander home I started checking everything to ensure serviceability. Using an adapter plug, I plugged the rig into an outside outlet using a 12 gage wire extension.
The 13,500 Btu AC ran fine on low, on high everything shut down. Inside the house the 15 amp circuit breaker had tripped because that is what circuit breakers do when you ask for more amps than they are rated for.
Damage to electrical things usually happens when the voltage or frequency is off - typically from a generator, not commercial utility company power.
nrgtrakr is offline   Reply With Quote
Old 07-21-2015, 04:19 PM   #8
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Be aware of what else might be on the circuit in your friends house. Even with everything in the trailer turned off but the AC, you may have problems if the circuit has other loads that you don't know about.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 07-21-2015, 04:23 PM   #9
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Biggest caution is to plug directly into the outlet and don't use an extension cord. That helps protect against voltage loss. Also occasionally check the adapter plug that converts your 30 amp plug to one that fits into the outlet. I personally had a situation where one of those conversion plugs did not have the proper gauge wire and physically started melting down and could have started a fire. At the time I was running a 13.5K air conditioner on my SOB trailer.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-21-2015, 04:26 PM   #10
dznf0g's Avatar
Oswego , Illinois
Jack
Me too.....
-Rich-
Old 07-21-2015, 04:29 PM   #11
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
The breaker box in my 73 Argosy has only 15A breakers in it. The question of what else is running comes into play but 20A should be OK.
Gearheart is offline   Reply With Quote
Old 07-21-2015, 04:41 PM   #12
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
I wondered also........20 amps safe???
Last week I wanted to work in my Bambi and had the same question. Since the temps were in the mid and upper 90s I decided to try it and find out. It has the original equipment 11,000 btu Penquin, so it's 14 years old and still works great. Purposely, I didn't use an extension cord, plugged the trailer cord directly into my surge supressor and on into a 20 amp duplex outlet, with an adapter of course.
It ran just like it always has on 30 amp power, will totally freeze you out. With temps so high it was getting a good workout. I did periodic checks to see if the cord heated up, looked at amp draw and voltage levels. It stayed on for 3 days. On the last day, I wanted to see the effect with the fridge turned on electric. It's small, a Norcold N300. Without the fridge it did not go above 12 amps, with the fridge it didn't go above 15 amps and mostly stayed at 14. A pleasant surprise....
I wouldn't do it with my 23, bigger ac unit, but I think I cured myself of the fear of using it on 20 amps if I really need or want to.
'01 16' Bambi --- Swee' Pea
'13 23D International --- Trixy
'09 Silverado --- Big Bertha
Adoptee -- '78 Argosy 24' Moho -- Big Girl
tinbender is offline   Reply With Quote
Old 07-21-2015, 04:44 PM   #13
tinbender's Avatar
2001 16' Bambi
Forgot to say.... my 30 to 20 adapter is made with 10 ga wire.
Old 07-21-2015, 05:21 PM   #14
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Start up is where the damage to the A/C is going to occur. The sell what is called hard start capacitors to replace the one currently installed. Basically it is a larger voltage storage device so when the compressor kicks in it gets the initial load from it vice dropping the current and doing damage. It then " recharges" while running at normal wattage draw.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Breaker, Breaker!! Bing-Bing Generators & Solar Power 25 09-24-2013 08:25 PM
breaker breaker project66 Batteries, Univolts, Converters & Inverters 4 05-29-2012 08:37 PM
PO rewired my 12V to run only 110V AirSpleen Electrical - Systems, Generators, Batteries & Solar 3 04-06-2007 01:26 PM
Rust: Red Flag? Deal-breaker? Run away? j_c_c Buyer Guidelines 4 08-24-2006 07:10 PM
