Old 09-14-2014, 02:44 PM   #1
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Can Grey Water Vent be source of Musty Odour?
Looking for some advice.
We've got a 2002 19' Bambi and over the last couple of trips have noticed a mild but intermittent musty odour that seems to be coming from under the bed and the fridge.
Thought I must have a leak so today exposed the area under the bed and also the frig. Everything seems dry, there is no visible evidence of a leak - and no musty odour today.
Am now starting to wonder if it is possible that the odour could come from the grey water vent? (located under the bed).
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 09-14-2014, 02:59 PM   #2
1987 25' Sovereign
Oregon , Ohio
Just a couple of thoughts. Looking at your trailer lay out I see that the shower is next to the bed. Do you make sure that there is always water in the shower drain trap. Where do the vents go up through the roof.
msmcv51 is offline   Reply With Quote
Old 09-14-2014, 04:14 PM   #3
1981 31' Excella II
New Market , Alabama
Water can get under floor coverings and cause rot problems you can't see.
Perry
Old 09-14-2014, 04:21 PM   #4
RangerJay's Avatar
2002 19' Bambi
Images: 44
Fairly certain the shower is not the source - we use it regularly - pretty much on a daily basis - so the only opportunity for the P-Trap to empty is when we are travelling - and there is no musty odour inside the shower/toilet area - only towards the head of the beds (we have bunks and the head of the beds are at the frig end) and in the storage space under the frig.
Think I will change the vent anyway - it will either deal with the issue or eliminate it as a possibility.
Jay
(Oscar Wilde)
Old 09-14-2014, 04:22 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
get a moisture meter
I could not see the moisture under my bed, until I removed the plastic covering, removed the carpet, and removed the carpet pad. The plywood underneath was soaked.
The only way to know is either remove all flooring or get a moisture meter with probes that will reach through.
Alan
Old 09-14-2014, 04:27 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I had a similar odor. Turned out to be a decomposing mouse. Cleaned him out and odor went away.
MICHAEL
Old 09-14-2014, 04:49 PM   #7
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Jay, how about a tiny propane leak in the fridge piping? Jim
Jim Flower is offline   Reply With Quote
Old 09-14-2014, 05:03 PM   #8
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Also, watch for this going by the Lakehead tonight. Heading home. Click image for larger version
Name:	ImageUploadedByAirstream Forums1410735700.194392.jpg
Old 09-14-2014, 05:12 PM   #9
RangerJay's Avatar
2002 19' Bambi
Images: 44
I'm envious - we didn't really get our "Superior" fix this year - and we're missing it - enjoy your trip home.
Jay
(Oscar Wilde)
Old 09-14-2014, 05:18 PM   #10
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
It's actually one of my sons heading back to Montreal after a summer in Alberta. My wife and I just got back last night from a dash to Florida. See where did you wake up this Sunday. Jim
Old 09-14-2014, 05:19 PM   #11
RangerJay's Avatar
2002 19' Bambi
Images: 44
Alan/Perry,
Thanks for the tip - will work to peel back at bit more of the floor covering and see what I can find.
Jay
(Oscar Wilde)
musty odor Elaine and Bohdan Dehumidifiers & Ozone Generators 20 12-08-2015 12:18 AM
musty carpet odour from leak anniem Upholstery, Blinds, Walls & Interior Finishes 5 09-01-2014 07:34 AM
Musty odor: water damage? Ssmookler General Repair Forum 9 08-17-2014 08:41 PM
Water tank odour Dan S All Argosy Trailers 3 08-27-2012 08:47 PM
Old Musty Smell rebelstand General Interior Topics 29 07-08-2011 04:51 PM
