Old 06-07-2015, 09:59 AM   #1
1962 19' Globetrotter
2001 31' Excella
Can anyone tell me what this is??
So three of these came with my trailer. So far I haven't found a use for them. I'm wondering if they could be for the manual use of the electric jack?
Name:	ImageUploadedByAirstream Forums1433692753.708978.jpg
Craig is offline   Reply With Quote
Old 06-07-2015, 10:02 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
They look like the manual crank handles for an electric tongue jack. One of these would be used if the motor failed.
Brian
SuEllyn & Brian McCabe
Old 06-07-2015, 10:58 AM   #3
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
did it come with any awnings?
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 06-07-2015, 11:07 AM   #4
2001 31' Excella
I do have an awning, but can't see how these would be used for that...
Old 06-07-2015, 11:11 AM   #5
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
moosetags got it right.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-07-2015, 12:22 PM   #6
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
You have three, might need one. PO must have found out that they are small and easy to misplace. I'd suggest you keep all three, in three different places you'll think to look in a crisis.
If your tongue jack fails to work electrically, pull the jack head off and it will reveal the socket for the crank.
Be sure to "time" the jack head per the manufacturer's instructions (available online) when you reinstall it. The idea is for the limit switches to stop the motor before the jack reaches its mechanical stops. Our PO failed to do that, so a jack failure was our very first challenge with the trailer.
Sorry, I don't have a link for those instructions. When you find them, print a copy and put it in the trailer.
Old 06-07-2015, 01:04 PM   #7
2013 20' Flying Cloud
Between Here and There and Nowhere , what have you got?
You access the keyway for the cranks by pulling off the top cap of the jack
openroad118 is offline   Reply With Quote
Old 06-08-2015, 11:35 AM   #8
1996 25' Excella
Tillsonburg , Ontario
To time the electric jack, you manually wind the jack all the way up while the tongue is supported either on blocks or the tow vehicle. Note the direction the jack screw winds, when going up and then run the motor all the way in the same direction until it stops before remounting the head on the jack. The jack should then run down only (...not up) once it is all back together. Be careful with the wires...they are stiff and short, not much wiggle room. I broke the power line off the switch when pulling the head for limit switch replacement. Took a while to figure where to re-solder it
JCW
JCWDCW is offline   Reply With Quote
Old 06-08-2015, 11:44 AM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I only have one...
You're really lucky to have 3...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-08-2015, 01:04 PM   #10
kenajen's Avatar
1972 23' Safari
2005 30' Land Yacht 30 SL
Miamisburg , Ohio
I would say that your Globetrotter has had three electric jacks in its wonderful life. They should all work on your current model.
kenajen is offline   Reply With Quote
Old 06-10-2015, 03:22 PM   #11
heavyjumbo's Avatar
2007 25' International CCD FB
Salisbury , Maryland
Yeah,keep them. Your batteries could fail when you are boondocking and then you would surely need them. The access for my 2007 Int. is to twist off the little level bubble on top of the jack then you can manually screw the jack.
heavyjumbo is offline   Reply With Quote
Old 06-11-2015, 05:27 AM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Open the top of your tongue jack and figure out which one 'fits'/works. The others, maybe fleabay can help dispose of them
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Can anyone tell me what tires I need? :) Sadie08 Tires 11 12-14-2010 04:43 PM
Can anyone tell me what this is?? Silver Threads General Motorhome Topics 4 05-11-2010 10:36 AM
help!! can anyone tell me how to convince my hubby! staceydr200 2005 and newer - Bambi all models 23 10-05-2008 10:03 PM
Can anyone tell me.... BIGED52 Off Topic Forum 14 02-17-2007 12:50 PM
Can ANYONE tell me what this is?!?! duke208 Our Community 30 11-11-2004 05:17 PM
