So we took our brand new 2019 25' FCFB out on its 1st trip last month and boy! Did it get put through it's paces! Screws came out of so many cabinets I couldn't believe it! We were able to fix pretty much everything ourselves with the exception of two things (one that is very annoying but if I have the part, can fix it myself). One of hinges in the cabinet above our slide-out pantry (the very narrow one), came part way off and is missing the part to screw back in place. So what is the easiest way of going about this? Calling our dealer's service dept and asking them about sending us a replacement part (is this something that should be under warranty)? Or just order a replacement part? Our dealer is about an hour away and hitching up is a pain as we store the AS at a friend's house and parking requires getting out the trailer valet to do a 180 turn to back it up. This should be the hinge...TIA!!
Sorry to hear your 2019 has so many screws loose! I have a 1978 31' that I've owned for 17 years and pulled thousands of miles! No leaks and I replaced 2 cupboard doors with piano hinges! I don't think I could survive paying the cost of a new one and having the problems you owners do! It's just sad!
The hinge you show is a Euro hinge that Airstream seems to love.
Is it broken or did the two halves separate? There's a tab at the end that if bumped releases the two parts. Easy to reassemble.
The tab is M.I.A, unfortunately, which is why we need to replace it Super frustrated about the whole thing.
I bought some plastic clips that keep you from accidentally disconnecting the halves. They work well
Where did you get your clips from? I think that the plastic clip may not have even been on the hinge?? I'm quite shocked at all the things that came apart on the "maiden voyage" 🙄
I solved this problem on mine using the clips. Another post when someone had the problem revealed the source. Search for more posts on this and you should find the one I mean
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
