Old 07-10-2019, 11:55 AM   #1
NellBell's Avatar
2019 25' Flying Cloud
Kenmore , Washington
Cabinet Hinge
So we took our brand new 2019 25' FCFB out on its 1st trip last month and boy! Did it get put through it's paces! Screws came out of so many cabinets I couldn't believe it! We were able to fix pretty much everything ourselves with the exception of two things (one that is very annoying but if I have the part, can fix it myself). One of hinges in the cabinet above our slide-out pantry (the very narrow one), came part way off and is missing the part to screw back in place. So what is the easiest way of going about this? Calling our dealer's service dept and asking them about sending us a replacement part (is this something that should be under warranty)? Or just order a replacement part? Our dealer is about an hour away and hitching up is a pain as we store the AS at a friend's house and parking requires getting out the trailer valet to do a 180 turn to back it up. This should be the hinge...TIA!!
https://tse4.mm.bing.net/th?id=OIP.g...d=Api&rs=1&p=0
NellBell is offline   Reply With Quote
Old 07-10-2019, 02:41 PM   #2
1978 31' Excella 500
Barrie , Ontario
Loose screws
Sorry to hear your 2019 has so many screws loose! I have a 1978 31' that I've owned for 17 years and pulled thousands of miles! No leaks and I replaced 2 cupboard doors with piano hinges! I don't think I could survive paying the cost of a new one and having the problems you owners do! It's just sad!
Bev1940 is offline   Reply With Quote
Old 07-10-2019, 02:54 PM   #3
Mollysdad's Avatar
The hinge you show is a Euro hinge that Airstream seems to love.
Is it broken or did the two halves separate? There's a tab at the end that if bumped releases the two parts. Easy to reassemble.
Old 07-11-2019, 09:39 AM   #4
NellBell's Avatar
The tab is M.I.A, unfortunately, which is why we need to replace it Super frustrated about the whole thing.
Old 07-11-2019, 10:48 AM   #5
Flynavy's Avatar
1974 25' Tradewind
2008 25' Safari FB SE
Col. Station , Ohio
Take the hinge off and head to the local hardware/ home depot/lowes and get a new hinge. Should be less than $5.
Flynavy is offline   Reply With Quote
Old 07-12-2019, 12:53 AM   #6
NellBell's Avatar
Great idea! Thanks so much 😊
Old 07-12-2019, 08:30 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I bought some plastic clips that keep you from accidentally disconnecting the halves. They work well
2019 Ford Expedition Platinum
Old 07-16-2019, 06:51 PM   #8
NellBell's Avatar
Where did you get your clips from? I think that the plastic clip may not have even been on the hinge?? I'm quite shocked at all the things that came apart on the "maiden voyage" 🙄
Old 07-17-2019, 08:13 AM   #9
Opinionated newb...
wave man's Avatar
2018 25' Flying Cloud
League City , TX
I solved this problem on mine using the clips. Another post when someone had the problem revealed the source. Search for more posts on this and you should find the one I mean
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
wave man is offline   Reply With Quote
Cabinet Hinge Replacement Ernster Cabinets, Counter Tops & Furnishings 17 12-26-2018 08:07 PM
2005 International CCD cabinet hinge problems - or are we just stupid? YOGINA Cabinets, Counter Tops & Furnishings 6 11-30-2017 04:27 PM
Replacement Hinge for Curved Cabinet Door Hans627 Cabinets, Counter Tops & Furnishings 1 05-29-2017 07:11 PM
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-20-2010 11:39 AM
