Old 09-18-2015, 02:23 PM   #1
2012 16' Sport
Fortuna , California
Cabinet Door Latch Locked in Closed Position
We have a 2012 16' Bambi Sport travel trailer. A cabinet door latch seems to be in a locked position and will not allow the door to close properly. The cabinet door will not engage the latch... it seems to be in a closed position. How do I open the latch to an open position so it works properly again and how do I avoid it happening in the first place? Something must have occurred to cause it to be in this condition. Thanks for any assistance.
John4str is offline   Reply With Quote
Old 09-18-2015, 02:29 PM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Use a screwdriver or something similar to pry it open. Unfortunately a common problem.
Al - K4GLU is offline   Reply With Quote
Old 09-18-2015, 03:07 PM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Typical of the plastic latches Airstream uses. If it breaks, they install another one. No improvement to the problem.
Many of sun have switched to these brass catches:
Extruded Double-Ball Catches - Lee Valley Tools
Old 09-18-2015, 03:37 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Like Al says, it's not unusual for the latch to settle in the wrong position. Open another cabinet with that type of latch, look at how the latch is when it is normally open, then use a small screwdriver/pocketknife and flip the latch to the correct position.
SSquared is offline   Reply With Quote
Old 09-20-2015, 09:10 AM   #5
gecko's Avatar
2009 28' International
Pacific Palisades , California
Easy one!
This happens from time to time, usually because you push to close on a spot far away from the latch. Make it a habit to close any door using these latches fairly close to the latch itself.
Take a screwdriver and put the blade against the inside of the closed part of the latch through the area remaining open. Gently but firmly use the screwdriver as a lever to pop open the closed portion of the latch. Be careful to do it gently because the portion of plastic in the latch casing that you're using as a fulcrum can distort pretty easily (but this won't affect the functioning of the latch.) That's it!
If it happens to the same latch a lot, even though you're now in the habit of pushing the door closed fairly close to the latch, consider replacing the latch.
gecko is offline   Reply With Quote
Old 09-20-2015, 12:48 PM   #6
2012 16' Sport
Thanks for the suggestions. I will give it a try.
2013 Flying Cloud 23D roll-up shower door won't latch closed warmrain Sinks, Showers & Toilets 9 10-01-2013 07:52 AM
Door latch broke, after it was closed! frscott Exterior Restoration Forum 2 03-11-2012 01:34 PM
Screen door stuck in closed position ESCAPE POD Doors & Locks 4 10-31-2011 03:30 PM
Can't get door to latch closed drew05 Doors & Locks 10 01-12-2011 08:33 PM
interior cabinet latch stuck closed in 63 trotter ChicknKathy Cabinets, Counter Tops & Furnishings 5 03-04-2008 08:52 AM
