Old 05-27-2017, 06:39 PM   #1
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
bumper storage lid came loose - tape failed
Cleaning up my Safari getting ready for my first summer trip. When I raised the bumper storage lid I noticed the hinge was loose on one side and the lid was flopping a bit. I had never noticed the hinge is attached to the lid with double sided tape. The tape's adhesive had failed. I guess not to bad for an 18 year old piece of tape. But, I was surprised that there are no mechanical fasteners, not one rivet! I searched the forum to see if I could find anyone else reporting this issue, but did not find anything.
If I had not noticed, odds are I would be looking for a replacement lid soon, since I'm going cross country this summer.
Check this out
I added a rivet to both ends, problem solved temporarily. When I return I plan to replace the tape entirely and add several rivets.
Alan
Old 05-27-2017, 07:10 PM   #2
Mount Dora , Florida
My 2017 has just three rivets holding the hinge to the trailer. No tape, glue, or bubble gum, just three rivets.
Of course, the two pull and turn latches help secure the lid.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 05-27-2017, 07:46 PM   #3
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Repair on lid
Check this out
Attachment 286324
I think it's time for a more secure repair! I would start with new 3M double side tape and then drill a centered hole on each end of the hinge and add 1 rivet per side just to make it a more permanent fix. Ed
P.S. I know it is not the best look for your lid but to secure it I would do this or add a stainless bolt locknut to the ends of the hinge to secure the lid.
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 08-29-2017, 09:49 AM   #4
2004 25' International CCD
2012 25' International
slaton , Texas
I have the same problem on my 2012, 25' International , I guess my tape lasted for 5 years. so, thanks for the advise on repair. i'll just get some of the 3M tape and hope it holds for another 5 years..
gregg
gnowlin is offline   Reply With Quote
Furnace thermostat connection came loose... CraigCA 1970 - 1973 Sovereign 0 10-22-2015 09:33 PM
Rams heads came loose in roof locker blickcd Cabinets, Counter Tops & Furnishings 5 04-14-2013 07:23 AM
shower door frame came loose, 2003 safari jpar Sinks, Showers & Toilets 1 10-01-2012 08:40 PM
'71 overlander furnace igniter came loose zigzag Furnaces, Heaters, Fireplaces & Air Conditioning 0 11-24-2010 10:05 PM
Help With Lid on 1963 Bumper Locker? utee94 Ribs, Skins & Rivets 31 04-14-2009 01:46 PM
