Old 07-05-2016, 11:22 AM   #1
DuncanK1's Avatar
2015 30' Flying Cloud
Berrien Springs , Michigan
Bumper Locker - Make it Watertight?
My Flying Cloud 30's rear bumper locker is often wet (we live in Michigan). There is daylight at the sides and the front, the hinge may or may not be watertight. Has anyone got a cunning trick to make the box more watertight or should I just resort to resealable plastic containers for my tools?
DuncanK1 is offline   Reply With Quote
Old 07-05-2016, 12:06 PM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I didn't on the pull-out bumper drawer of our Classic....just took the BFH, gave the floor some drainage 'slope', drilled some 1/4" holes and installed some drainage tiles.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-05-2016, 12:16 PM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Due to to the location of the bumper drawer, I believe you would be sealing water in. I made sure mine drained well and only used it to store waste water draining equipment (hoses fittings etc)
Ken
Old 07-05-2016, 12:52 PM   #4
1974 25' Tradewind
Calgary , Alberta
Having just finished pulling the rear bumper, "trunk", black and gray tanks from the back of our '74, I would suggest the same as the others have. If anything, make sure that you have adequate drainage holes and that there is opportunity for these areas to vent either while stationary or while you're towing. And, don't keep anything on the floor surface of the trunk that will rust or wick water.
It's unlikely in the extreme that you will be able to prevent all water from coming in, but it is easy to make things "tight" enough to prevent the water from escaping or evaporating and create a moldy mess. The combination of water and road dust makes a really muddy soup and the easier you make it for yourself to pull everything out and hose things down in there, the better.
Alumineer is offline   Reply With Quote
Old 07-06-2016, 12:45 PM   #5
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
I took the factory mat out, drilled extra drain holes,cleaned the drawer very well then coated it with ordinary aluminum paint. I've repainted every two years and it has worked well. No rust, repels water, doesn't scratch off or peal very easily. I'll never put a mat in that can act as a dam or hold water in any way.
NOAZRK2690 is offline   Reply With Quote
Old 07-13-2016, 03:43 PM   #6
DuncanK1's Avatar
Thanks for the advice and ideas. I'm using a couple of plastic boxes for the small tools, and will drill a few more drainage holes next time I'm bored.
Now to find a long plastic box that fits in the compartment for my breaker bar, long handled wrench and torque bar.
Watertight for Winter??? Airstreamdmb Roof 2 11-04-2010 06:31 PM
Help With Lid on 1963 Bumper Locker? utee94 Ribs, Skins & Rivets 31 04-14-2009 12:46 PM
Roof Locker Latch for '66 Overlander draftwomyn21 Cabinets, Counter Tops & Furnishings 0 08-31-2006 03:39 PM
Where to find over head locker parts ibedonc Cabinets, Counter Tops & Furnishings 0 06-20-2006 10:33 AM
Roof locker extrusion needed mcneon Cabinets, Counter Tops & Furnishings 1 09-24-2004 09:00 AM
