Old 05-23-2008, 10:35 AM   #15
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Here are a couple of links regarding the dog houses.
http://www.airforums.com/forums/f239...use-26867.html
http://www.airforums.com/forums/f239...use-17657.html
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 05-27-2008, 03:27 PM   #16
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
59tradewind,
Here are the pictures I promised you...
I put the Mrs. in one for scale. She is 5'2"
ID:	61107   Click image for larger version
ID:	61109   Click image for larger version
ID:	61111   Click image for larger version
ID:	61113   Click image for larger version
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 06-08-2008, 02:32 PM   #17
Pensacola's Avatar
1975 31' Sovereign
Milton , Florida
We have a small one at Mystic Springs modeled after Dr. Holman's 1935 Airstream. I tried to upload a photo but can't. It was made by one of the members to tow behind a small 1957 Chevy in the 4th of July parade at international.
Pensacola is offline   Reply With Quote
Old 01-05-2009, 10:50 PM   #18
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Originally Posted by lovingtahoe View Post
Here is an article I had archived on the birdhouse Traveling in Style News : Abilene Reporter-News I would love to have one... or learn how to make one would be even better!
Just saw this picture and thought it was really cool. Love the vintage birdhouse!
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 01-06-2009, 08:03 AM   #19
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
This is a great idea and one I've contemplated. One such idea was to make our mailbox an Airstream where the front opens up on hinges but to have one with a cooler inside is even better. Keep these ideas coming.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 01-06-2009, 10:14 AM   #20
Aluminum in 3-D
Blue Pearl's Avatar
1968 28' Ambassador
Seaside , Oregon
Must have
I think there are a lot of brains going full speed on a Airstream Cooler. It will be the next must have at rallys, like fire in the can. Love the idea.
Teresa
Membership chair
Wally Byam Airstream Club
Past President Oregon Unit 090
Campfires, the original social media!
wbcci#29827
Check out the [URL="https://airstreamclub.org/"and Wally Byam Airstream Club on facebook
Blue Pearl is offline   Reply With Quote
Old 01-06-2009, 12:46 PM   #21
dreadydreame's Avatar
1965 26' Overlander
Newport , North Carolina
the #7 post in this thread looks like perfect size for your mini car
,Katie & Anthony, 2kids, lots of pets!
dreadydreame is offline   Reply With Quote
Old 02-23-2010, 12:58 PM   #22
1968 17' Caravel
minneapolis , Minnesota
this guy makes airstream doghouses, which might be close to what you are looking to do.
Chrome Dome Studio
AirstreamLov is offline   Reply With Quote
Old 03-02-2010, 04:29 PM   #23
1972 Travelux Princess 25
Cobourg , Ontario
If it was me I would start by making a mockup out of wood and cardboard. Cut a floor of plywood, and add bulkheads of plywood or wooden boards to make a framework for the body.
Copy all dimensions off your trailer, but smaller.
Cut out pieces of cardboard and tack them to the frame. If it doesn't come out right, so what? Throw away the bad part and get some more cardboard.
When it is all done you can carefully take it apart and use the cardboard as patterns to cut out the aluminum sheets.
It would also be possible to make the framework out of steel tubing (copied off your wooden frame) and rivet on the aluminum sheets.
Copy the body off one of the old models made out of all flat panels such as the "whale tail" or"13 panel end cap" models before 1955. Then you don't have to form any round shaped panels, they can all be cut out of flat sheets.
Probably the best way to make an opening lid, would be to have the end caps permanently fixed to the frame with an opening lid in between them.
For small wheels what about those dollies you can buy for moving furniture etc? I see them on sale for $39.99 or less and sometimes you can buy just the wheels at certain hardware and tool stores.
You would need to get a longer rod for the axle, or cut the original one and extend it.
How to make the windows, the easiest way would be to just paint them on.
For the trailer hitch, the old friction style sway eliminators had a small ball and socket joint, maybe you could use one of them.
It would be quite a project but not impossible if you were handy with tools.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 03-02-2010, 06:07 PM   #24
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
do virtual models count?
Picasa Web Albums - JOSEPH - AIRSTREAM MOD...
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Airstream to start building Class-C motor homes! Minnie's Mate Airstream "In the News" 12 04-18-2007 11:16 AM
Axis Products no longer building Airstream axles. Axis Axles 11 05-22-2006 08:56 AM
RV Building Code wkerfoot General Repair Forum 9 11-01-2005 12:21 PM
building an airstream model oxanimosity Off Topic Forum 7 04-09-2005 10:28 AM
? Building an icebox Stefrobrts Refrigerators 9 01-05-2005 04:56 PM
