Old 05-01-2012, 02:43 PM   #1
1976 Argosy 24
Lebanon , Pennsylvania
Rivet buck riveting
We were going over the exterior of our "76 Argosy & noticed some of the buck rivets are gone. Are these hard to replace? Any advice on the best tools and procedures to replace these?
heckbo76 is offline   Reply With Quote
Old 05-01-2012, 03:10 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You can use Olympic rivets. The tool required to finish the rivet head is special and very expensive. I have heard that they can be finished with a Dremel tool. But don't know what tool you would install in the Dremel. Maybe the convex stone.
TG Twinkie is online now   Reply With Quote
Old 05-01-2012, 03:20 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
To install bucked rivets you obviously have to get to the back side to hold the bucking bar. Many times that is not an easy option if the trailer in intact otherwise. If you only have a few to replace just use Olympic rivets and shave the heads (Steve has them at Vintage Trailer Supply). If you are going to use bucked rivets you need a good 3X rivet gun. Most aircraft supply houses have them, do not try to use an air impact hammer. Riveting is not hard but there is a learning curve. An old US Navy aircraft mechanic taught me. I would suggest lots of practice on scrap before trying to set any rivets on the skin of your trailer.
Again, it is not hard to do but takes some practice to get the feel of it. If you have a local airport find an older A&P mechanic, he will probably be glad to give you some tips. If you only have a few rivets, he might even help you.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-01-2012, 03:35 PM   #4
1976 Argosy 24
Thanks, good info. I do know someone at an airport that might be able to hook us up. I'll pass all this info to my hubby & let him decide.
