06-01-2018, 08:10 PM
#21
2000 25' Safari
Davidson County
, NC Highlands County, FL
Originally Posted by dugster
Airstream: Are you listening? This is a frequent problem for many owners. These trailers deserve a vent that can be operated from inside!!!
The vents of the older trailers did open from the inside.
Like Wally said a long time ago; make improvements, not changes!
Alan
06-02-2018, 06:43 AM
#22
2019 27' Flying Cloud
Kansas City
, Missouri
Thanks for the ideas. Think I will see if maybe a binder clip will do.
Piggy Bank
06-02-2018, 03:55 PM
#23
2018 28' Flying Cloud
highlands ranch
, CO
Originally Posted by Journey'81
Yeah ours broke off too. AS dealer (had a list of items to be fixed under warranty) tried to replace the tiny plastic without success. They ended up replacing the outer assembly.
I have a feeling it will break again as it is too fragile. Like the idea of using a tiny clip from Wanderer.
second the ace recommendation ... actually like it better than original.
nylon screw & nut, 2 nylon washers & "screen holder" (either plastic or nylon).
06-02-2018, 04:41 PM
#24
LEV ZEPPELIN
2004 19' International CCD
Chicago
I love the clothes pin idea! The original tabs on ours are useless. I’ve been wedging a small stick in mine just to keep them in closed position while traveling but that is just dumb
06-02-2018, 10:05 PM
#25
1987 Avion 34W owner
Good Ol'
, USA
How about these.... Get rid of the crappy plastic.....
https://www.lowes.com/pd/Prime-Line-...h-Clip/3080661
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
06-06-2018, 12:04 PM
#26
Creampuff
2022 27' Flying Cloud
2016 25' International
Airstream - Other
Malibu
I have a vent on a donor 2014 30FB that was a rollover. The hood is broken but the tabs are good. I can send you one. After reading this thread I'll want to keep the 2nd for a spare.
PM me if needed.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
06-06-2018, 01:15 PM
#27
1992 34' Excella
Humble
replacement cover
Purchased a replacement to the vent cover. Came complete and quite reasonably priced.
1 x Range Hood Exhaust Cover Polar 31-8485 (31-8485) $17.95
From Out of doors mart
www.outofdoorsmart.com
mine was for a 1992 Excella.
Originally Posted by Piggy Bank
Last weekend one of the little (plastic) pivoting clips that holds the range hood vent damper closed on the outside broke off.
Does anyone have a good idea on a fix?
06-06-2018, 05:17 PM
#28
2011 27' FB Flying Cloud
Box Elder
, South Dakota
There must be a better way !
After replacing the white, painted, peeling, piece of junk vent cover with another black, non-painted, piece of junk cover, I continued to experience the same turn-lock breakage. One day while in the electrical dept. at my local Home Depot or my local Ace, (not sure where),I found a bag of small aluminum wire clamps. With two of these, two SS screws, two SS washers, a drill, a screw driver and me trusty step stool, I was able to fashion new hold-downs. I also added a tiny bit of super glue to the tip of the screws to keep them from turning.
06-27-2018, 12:52 PM
#29
2015 19' International
Boise
, Idaho
I emailed Ventline through their website and explained this exact situation. The representative was prompt, asked for my address and agreed to mail a few of those flapper retainer clips out to me. Should be arriving this week.
Steve
01-04-2019, 07:35 PM
#30
2005 31' Classic
Venice
I only secure when in storage...not while traveling.
01-05-2019, 06:55 AM
#31
2014 27' Flying Cloud
Stowe
, Vermont
I use a mini clip - like you would put on your refrigerator to hold notes or small pictures.
01-05-2019, 08:22 AM
#32
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
We installed one of these before the AS Store got a hold of them and raised the $$$ 100%. 😠
The weight holds it closed and a custom clip holds it open when in use.
If forgotten about the clip will allow it to close at speed while underway, it is advised to keep the clips in stock. 🤓
06-10-2019, 09:23 PM
#33
2018 27' International
Hillsboro
I rigged up two closure levers from the nuts and bolts drawers at the hardware store using the existing holes. Little bolts that would go through the holes with double nuts and double washers. Between the washer you put a little screw eye. With the bolt going through the eye so it rotates over the vent flap. I added a short piece of 1/8 fuel line for friction and to provide a little handle. Looks and works great $5.00 and should never have to worry again.
06-13-2019, 09:14 AM
#34
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Broken little clip on flap of stove vent hood damper
Originally Posted by PaulnGina
These are no longer available from Lowes but I did find a 4 pack at my local ACE hardware in the screen repair section.
