Old 03-28-2012, 01:57 AM   #1
1978 Argosy 30
vancouver , British Columbia
broken door latch.....AHHHHH!!!
hey I have a 78 30 ft argosy that I just broke the latch off the door.
a) where can I get a new/used one
b) how the ____ do I get in now?
and of course the answer is no,
none of the windows are open.
dan-argosy is offline   Reply With Quote
Old 03-28-2012, 03:41 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here is the handle at least:
Keeler Lock Exterior Handle Reproduction
Old 03-28-2012, 07:52 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is the handle physically broken off or is it just inoperable? If the handle lifts but the door doesn't unlatch you have probably broken the roll pin that pulls the bolt back to open the door. It can be repaired.
Old 03-28-2012, 07:56 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Check here...West Coast time. Both Greg and Andy are very helpful on how to get in and get a replacement lock.
Old 03-28-2012, 05:30 PM   #5
1978 Argosy 30
Yes the handle is broken off. Only the pin is remaining and the pin itself is not attached at the top.
Old 03-28-2012, 07:05 PM   #6
funkill's Avatar
reno , NV
Images: 27
When my handle was broken, I too had no open windows. And dogs inside. I opened one of the exterior access compartments and crawled inside. I knew the compartment where my fuse panel would lead me to the bedroom. It was a bit tight but I made it. When I popped up through the bottom of the gaucho/bed, the pups went crazy. A new meaning to "prairie dogging".
Good luck - Laura
funkill is offline   Reply With Quote
Old 03-28-2012, 09:17 PM   #7
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Good luck - Laura
Man, I would need to go on a Reallycrash diet. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-29-2012, 10:03 PM   #8
1978 Argosy 30
I got in....I surgically removed pieces of the cast aluminum with a zip disc on a grinder.
I will try and post pics. if you cut the bottom 5\8ths of an inch off just bellow the lock, you can you can operate the latch using a screw driver
door handle susans69 All Argosy Trailers 26 05-30-2017 10:23 PM
Switches at door batt Lights - Interior & Exterior 4 10-24-2012 07:07 PM
Note in the House Door dscluchfc Our Community 32 08-29-2012 05:09 PM
2006 Safari 23' with broken Dometic freezer door springs Goal15 Refrigerators 5 08-16-2012 06:17 AM
Relocate door ewaegeman Doors & Locks 12 03-27-2012 06:28 PM
