Old 06-02-2009, 12:11 PM   #1
2004 16' International CCD
Bozeman , MT
Broken cabinet and shower brackets
I have a 2004 16 foot Bambi interenational and some of the plastic bracket in the inside of the cabinet that hold the cabinet attached to the wall have broken and others have just pulled off. Now the cabinet is starting to push out. I used bigger screws on the ones that had pulled out but I don't seem to find anything solid to screw them in other than the aluminum. Is that all the cabinet is screwed on to? Just some thin aluminum? I also have an other bigger plastic bracket that holds the bathroom wall that also broke. Where can I buy these brackets? I can use some metal L brackets in the inside of the cabinet but it wouldn't be too pretty on the outside wall. Or is there a problem with using metal ones?
Thanks for the info!
Paolo
marchesi is offline   Reply With Quote
Old 06-12-2009, 08:17 PM   #2
Turtle's Avatar
Arcata , California
I have the same issue with the brackets. I couldn't find replacement plastic so I opted for the unsightly L ones. And I added a few extra. Seems to be hold things in place. Jamie
Turtle is offline   Reply With Quote
Old 06-12-2009, 08:27 PM   #3
brackets
Those brackets are available from a few parts stocking dealers.
The usual cause for them breaking, is lack of proper running gear balance.
Picture of the brackets swanky Mechanics Corner - Engines, Transmission & More... 4 07-12-2009 07:25 AM
Source for AC and PS Brackets guy99 Mechanics Corner - Engines, Transmission & More... 21 12-07-2008 10:28 AM
Wall tracks/ brackets firelily007 General Repair Forum 2 04-17-2008 03:09 PM
Need bunk bed brackets Safari Tim Cabinets, Counter Tops & Furnishings 8 05-01-2007 11:20 PM
Attaching Awning Brackets Mike Rhodes Awnings 7 10-30-2002 07:35 PM
