Old 07-14-2019, 11:28 AM   #1
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Broken bath air exhaust handle
2019 FC 26, the handle for the push-up, pull-down bathroom exhaust fan broke in half. Is this a replacement part, or a whole new unit? Warranty item?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 07-14-2019, 12:20 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
https://www.etrailer.com/Accessories...VA0207-05.html
CRH is offline   Reply With Quote
Old 07-14-2019, 12:30 PM   #3
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
That's the correct piece. Maybe your dealer will give you one if you ask, though technically not a warranty item (just a poorly executed product.)
Order two while you're at it to have a spare. Easy quick fix with two screws. I am careful and tell others to pull down on both sides of the handle, do not pull down from the middle (like's it's designed to do but it's a piece of junk).
pcskier is offline   Reply With Quote
Old 07-14-2019, 01:23 PM   #4
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Iíve replaced one. Terrible design. Best advice is to use 2 hands to pull it down - one on each end of the plastic bar. Good luck!
SteveSueMac is online now   Reply With Quote
Old 07-14-2019, 01:48 PM   #5
Quick and easy - you guys are the best. Ordered two - thanks again,
WBCCI #6679
Old 07-14-2019, 06:08 PM   #6
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Temporary repair
Our shower ventís handle cracked but was still intact. You canít pull it down far enough to reach the screws so it will be a warranty repair next trip to the dealer.
That said, weíve got a trip to Colorado in August so I did a quick repair so itís usable. I found a strip of stainless steel at the local Ace Hardware and cut it to length.
I did superglue the crack then attached the metal strip to the handle with 10# double sided Gorilla tape. Unfortunately it cracked again and the spring in the steel started to pull away on the ends. Pop rivets to the rescue! Itís not pretty but is stronger than the plastic handle that it came with!
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB (traded)
2019 Ram 2500 Laramie Blue Ox 1500#
2019 Ram 1500 Laramie Sport,
2020 Retirement Plan
jeffmc306 is offline   Reply With Quote
Old 07-15-2019, 09:10 AM   #7
1996 25' Excella
Tillsonburg , Ontario
I broke one on my '89 in Texas and made up one out of oak that worked very nicely
Just broke the one on my '96...will be making up a new one also in oak. Just shaped a piece to fit the straps and screwed into the ends of the handle using same holes as the plastic mount.
JCW
JCWDCW is offline   Reply With Quote
Old 07-15-2019, 09:13 AM   #8
1996 25' Excella
While on this topic
Does anyone know of a quieter fan that will fit this application. Both my fans are screaming banshees...hate using it!
JCW
Old 07-15-2019, 09:30 AM   #9
2007 27' International CCD FB
San Diego , California
Originally Posted by JCWDCW View Post
While on this topic
JCW
When I looked for an upgrade option, I couldn't find anything available in the market.
I like to run my bathroom fan 24/7 to always ensure a fresh bathroom, but also to keep some circulation in the trailer to avoid condensation build-up at night. It's ridiculously loud to try to do that stock. And draws more amps than necessary.
Here's a homebrew solution. Why it didn't come stock like this, or as an option, I can't figure out. Would be less than a $2 OEM part. It works beautifully!
http://www.airforums.com/forums/f455...od-191363.html
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 07-15-2019, 09:49 AM   #10
2000 25' Safari
Denver , North Carolina
ID:	346696 My solution. Been up for 2 years so far.
mbubbaca is offline   Reply With Quote
Old 07-15-2019, 09:55 AM   #11
BoatnutG2
BoatNutG2's Avatar
2015 28' Flying Cloud
Fountain Valley , California
Mine were screaming also. When investigating I found that the expanded foam rubber seal had slipped down and was hitting the blades. When I removed the foam the sound became tolerable. But I have not come Up with a good solution to replace the foam rubber seal.
BoatNutG2 is offline   Reply With Quote
Old 07-15-2019, 10:11 AM   #12
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
Mine broke too. I repaired it like mbubbaca did. Mine has been functioning fine now for 4 years.
jimfa440 is offline   Reply With Quote
Old 07-15-2019, 12:41 PM   #13
You can remove the interior beauty ring/shroud via the 3 exposed screws on the perimeter. This will give you access to the two handle screws.
Old 07-15-2019, 01:02 PM   #14
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Hey, that's what I want to do! How is the speed controller wired into the fan? Can you draw a schematic?
My handle broke and I bought one when I was at airstream the other day. Didn't think to have Airstream service fix it. Oh well, the handle looks easy enough.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Support Airstream Forum***
turk123 is offline   Reply With Quote
Broken jack & broken manual crank handle!! jaybauman Jacks, Stabilizers, Lifting and Leveling 34 07-08-2019 05:10 PM
Broken exhaust manifold bolts SStar Tow Vehicles 16 03-07-2014 03:26 PM
Bath room exhaust fan handle Support Admin Airstream Classifieds 0 09-22-2013 03:00 PM
bathroom exhaust fan handle replacement charlie tuna Roof Vents, Skylights & Fans 8 09-08-2006 06:40 PM
Bath exhaust fan walter1 Roof Vents, Skylights & Fans 8 01-24-2005 06:27 AM
