07-14-2019, 11:28 AM
Trailer Sold, Waving
2019 26' Flying Cloud
Stettler
, Alberta
Broken bath air exhaust handle
2019 FC 26, the handle for the push-up, pull-down bathroom exhaust fan broke in half. Is this a replacement part, or a whole new unit? Warranty item?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
07-14-2019, 12:20 PM
1995 25' Excella
xxxxx
, xxxxxx
07-14-2019, 12:30 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
That's the correct piece. Maybe your dealer will give you one if you ask, though technically not a warranty item (just a poorly executed product.)
Order two while you're at it to have a spare. Easy quick fix with two screws. I am careful and tell others to pull down on both sides of the handle, do not pull down from the middle (like's it's designed to do but it's a piece of junk).
07-14-2019, 01:23 PM
2012 27' Flying Cloud
W
, New England
I’ve replaced one. Terrible design. Best advice is to use 2 hands to pull it down - one on each end of the plastic bar. Good luck!
07-14-2019, 01:48 PM
Stettler
, Alberta
Quick and easy - you guys are the best. Ordered two - thanks again,
WBCCI #6679
07-14-2019, 06:08 PM
2019 27' Globetrotter
McHenry
Temporary repair
Our shower vent’s handle cracked but was still intact. You can’t pull it down far enough to reach the screws so it will be a warranty repair next trip to the dealer.
That said, we’ve got a trip to Colorado in August so I did a quick repair so it’s usable. I found a strip of stainless steel at the local Ace Hardware and cut it to length.
I did superglue the crack then attached the metal strip to the handle with 10# double sided Gorilla tape. Unfortunately it cracked again and the spring in the steel started to pull away on the ends. Pop rivets to the rescue! It’s not pretty but is stronger than the plastic handle that it came with!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
07-15-2019, 09:10 AM
2012 23' FB International
Woodstock
, Ontario
I broke one on my '89 in Texas and made up one out of oak that worked very nicely
Just broke the one on my '96...will be making up a new one also in oak. Just shaped a piece to fit the straps and screwed into the ends of the handle using same holes as the plastic mount.
JCW
07-15-2019, 09:13 AM
Woodstock
, Ontario
While on this topic
Does anyone know of a quieter fan that will fit this application. Both my fans are screaming banshees...hate using it!
JCW
07-15-2019, 09:30 AM
2007 27' International CCD FB
San Diego
Originally Posted by JCWDCW
While on this topic
JCW
When I looked for an upgrade option, I couldn't find anything available in the market.
I like to run my bathroom fan 24/7 to always ensure a fresh bathroom, but also to keep some circulation in the trailer to avoid condensation build-up at night. It's ridiculously loud to try to do that stock. And draws more amps than necessary.
Here's a homebrew solution. Why it didn't come stock like this, or as an option, I can't figure out. Would be less than a $2 OEM part. It works beautifully!
http://www.airforums.com/forums/f455...od-191363.html
07-15-2019, 09:49 AM
2000 25' Safari
Denver
, North Carolina
My solution. Been up for 2 years so far.
07-15-2019, 09:55 AM
BoatnutG2
2015 28' Flying Cloud
2023 23' Flying Cloud
2013 Interstate Coach
Huntington Beach
Mine were screaming also. When investigating I found that the expanded foam rubber seal had slipped down and was hitting the blades. When I removed the foam the sound became tolerable. But I have not come Up with a good solution to replace the foam rubber seal.
07-15-2019, 10:11 AM
2019 25' Flying Cloud
Greeneville
, Tennessee
Mine broke too. I repaired it like mbubbaca did. Mine has been functioning fine now for 4 years.
07-15-2019, 12:41 PM
San Diego
You can remove the interior beauty ring/shroud via the 3 exposed screws on the perimeter. This will give you access to the two handle screws.
07-15-2019, 01:02 PM
2019 30' Classic
Canfield
, Ohio
Hey, that's what I want to do! How is the speed controller wired into the fan? Can you draw a schematic?
My handle broke and I bought one when I was at airstream the other day. Didn't think to have Airstream service fix it. Oh well, the handle looks easy enough.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
07-15-2019, 01:35 PM
2019 30' Classic
Canfield
, Ohio
Second thought, it looks pretty simple. From the on-off switch to the speed controller and back to 12v.
Tom & Doty
07-15-2019, 03:41 PM
Overland Adventurer
2009 34' Panamerica
Telluride
I use silicone spray to keep ours moving smoothly. The difference is very obvious.
07-15-2019, 07:17 PM
McHenry
Pteck, thanks for the tip but I think your fan is closer to the side wall and thus has a shorter trim ring. My fan is on the inside near the shower door and the handle sits in the middle of the roof.
I can see the left hand screw but the right is not visible. I can put a finger on it but there’s not enough room for a short stubby Phillips. Maybe a right angle ratcheting Phillips would do it. My guess is the vent has to be removed from the roof to access the handle. It can wait for the next warranty visit to the dealer!
2018 FC23FB
WBCCI# 10258
RETIRED!
07-15-2019, 08:52 PM
1960 28' Ambassador
1998 25' Safari
Avonton
, Ontario
I did this with every fan in the trailer. works great with the fantastic fan and the fan in the stove hood.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
07-16-2019, 08:29 AM
Anywhere
, Alabama
Even with trim ring removed there is no room to get to screws.
Matt & Pam Padgett
Anywhere, USA
2016 Ford F-350 Dually
07-16-2019, 08:30 PM
San Diego
Ah, that's unfortunate! The fan is a really old design with poor consideration for maintainability. In lieu of some trick screwdriver tool, the only other way to get at the screws is indeed to remove the cover from up top.
