Old 05-26-2019, 08:06 AM   #1
Free range's Avatar
1993 21' Sovereign
Red deer , Alberta
Breaker trips when fridge is on.
We got our self a new to us 93 21' Sovereign AS. The trailer had been sitting un used for 6 or 7 years. I took it home and checked everything out. For the most part everything works. The hot water heater works but flutters and doesn't heat the water very fast (orange flame) the inverter makes big buzzing sound, furnace works fine, and the fridge works fine on propane but as soon as I switch it over to electric the breaker trips. So I unplugged the electrical fridge cord and plugged it directly in the house outlet but the breaker trips right away. What am I missing?
Free range is offline   Reply With Quote
Old 05-26-2019, 08:37 AM   #2
1986 31' Sovereign
Miami , Florida
The 120v that the refrigerator uses goes through a relay and then is applied to a small heating unit that sits in a groove adjacent to the flue.
I would open the back of the reefer and check to see if any little creatures have gnawed on any wiring. If not, then remove one lead on the heating element and plug it in. If the breaker doesn't trip, most likely that heating element is bad (shorted).
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-26-2019, 08:50 AM   #3
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
Terminology. You’re not likely to have an inverter so it’s probably the converter that is buzzing. Probably because it’s charging dead or bad batteries are hard as it can go. These issues don’t seem to be related. Orange flame on the “hot” water heater. could be flue plugged up. Or low pressure or a dirty jet. Make sure it’s not in a partial winterize mode and the outside shower valves (if it has one) are off. When fridge trips the breaker, is it the one in the AS panel ? When you plug fridge (and only the fridge) into house socket, can I assume the breaker that trips is at the house?
By being so focused on how things 'could' be, we are under-appreciating how great things already are - Timber Hawkeye
Wolfwhistle is offline   Reply With Quote
Dometic A/C Trips the Circuit Breaker Often Rum Runner General Repair Forum 3 09-14-2014 11:24 AM
120 volt circuit breaker trips JIM CALDWELL General Repair Forum 2 06-15-2014 03:16 PM
20 amp Breaker Trips when HOT Silver Otter Electrical - Systems, Generators, Batteries & Solar 6 07-05-2012 12:07 PM
breaker trips with new convection oven & AC silver 67 Electrical - Systems, Generators, Batteries & Solar 5 06-08-2012 04:17 PM
Converter trips breaker Wolfie Electrical - Systems, Generators, Batteries & Solar 5 04-02-2011 10:08 AM
