Old 01-20-2013, 11:28 AM   #15
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by steveirving View Post
What is a Univolt?
Univolt is what the original converters in vintage Airstreams were called.
Many people still call converters Univolts regardless of brand, the same way some people (at least use to) call all copiers Xerox.
Old 01-28-2013, 10:14 AM   #16
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Break away switch is now fully functional. Thanks to all the helpers.
steveirving is offline   Reply With Quote
Old 05-30-2013, 03:18 PM   #17
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
blowing fuses
I have a 65 caravel w/the same problem. while towing, the reset type fuse in the breakaway circuit blows and resets itself continually, and the brake controller goes off and on each time. the car is wired correctly( I had it checked) and all the other trailer lites work correctly. how do you check for shorting or ground problems if the wire disappears into the shell or frame?? joe in MN
joqin is offline   Reply With Quote
