Old 03-07-2012, 02:57 PM   #1
TeamD's Avatar
1968 24' Tradewind
Canoga Park , California
Brake replacement for 1968 Airstream
So I was wondering if I could get some advice about replacing break pads on my Airstream, I have only worked on drum brakes 10 years ago on a 1967 Mustang, before I dive in to work on my Airstream brakes that needs pads, is it worth it? Are there any oddities, I am a little afraid to open it and not be able to put it back together!
Any advice I would appreciate it!
Susie
TeamD is offline   Reply With Quote
Old 03-07-2012, 03:34 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Susie
Electric trailer brakes are generally simpler in construction than car brakes.
You should consider purchasing loaded backing plates instead of just shoes. The loaded backing plate will include the shoes, magnets, and other hardware. Usually the magnets will require replacement if the shoes are bad, and it is often cheaper to purchase the entire backing plate as an assembly.
You will want to repack or replace the bearings while you have the wheel apart.
Old 03-07-2012, 03:37 PM   #3
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Best to buy loaded backing plates from a place like Electric Trailer Brake Assemblies at Trailer Parts Superstore
about $40 a wheel and they just bolt right on.
Plan to repack the bearings at the same time.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 03-07-2012, 05:10 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
For a little more then the price of brakes and bearings you should replace the whole axle. At 44 years it will be hard and need replacing. The axle will come with brakes, drums, bearings and seals.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is online now   Reply With Quote
Old 03-07-2012, 10:02 PM   #5
TeamD's Avatar
1968 24' Tradewind
Thanks for the great feedback, I do love this forum! I am sure a dumb question but where do I buy an axle? I guess I get confused by the vintage part of the trailer, do I need to go to Airstream or just auto?
Old 03-07-2012, 10:58 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
axle
The place I refer folks to is Southwest axle.....I am sure there are other companies out there with comparables. Nice complete units...I used them on a 66 Caravel, a 69 Caravel etc...
Old 03-08-2012, 12:27 AM   #7
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Road Trip!
If I lived in Calif. I would look @ InlandRV.com for your axle needs. They can get you the most correct Airstream (OEM) axles that are made to bolt up on your current set-up without any modification. He will need your VIN number & model. These axles can come complete w/brakes and check with them on shocks as they will most likely need replacing too! Last time I looked they were on sale! Andy Rogozinski (Owner) can answer any questions you have on the axles or anything else on Airstreams. He is a wonderful resource to these forums. If you are willing to road trip to his dealership in Corona you can save yourself the delivery charges to ship them to you. He can advise you on having the entire axle assembly aligned and balanced for the best ride your trailer has had since it was new. Hope this helps, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 04-18-2012, 10:25 PM   #8
TeamD's Avatar
1968 24' Tradewind
Your information is sooo helpful! We ended up diving into the kitchen so we are not doing axle's this year. I have a trip planned about once a month these days so I need to do the brakes in the least. I am thinking I will buy the cheap brakes 12" x 2" Electric Brake Assembly - Left Hand / 5.2k #K23-105-00
Stock# 5331009
DEXTER 12" x 2" Left Hand complete electric brake assembly.
This brake is rated to a maximum capacity of 5200 lbs. per pair.
Reg. $39.99 ~ Sale Price $31.99
Is that strong enough? My initial feeling is to buy the highest weight rated but I assume I will be doing that next year with the axles.
Thank you thank you
1968, 1968 airstream
Tank side wall height for SeeLevel Sensors? mtntime Plumbing - Systems & Fixtures 1 06-15-2012 11:26 AM
The RETROMOBILE in this month's Airstream Life Eaglemate Airstream Lifestyle 7 03-08-2012 01:40 PM
Vintage 1969 31ft AIRSTREAM Sovereign International Travel Trailer RV eBay Watch Airstreams on eBay 0 03-07-2012 02:00 PM
Beautifully Renovated Vintage 1972 Airstream eBay Watch Airstreams on eBay 0 03-07-2012 01:10 PM
Propane Tanks -- Original Vintage Airstream Trailer eBay Watch Airstreams on eBay 0 03-07-2012 12:30 PM
