Old 06-30-2019, 12:30 PM   #1
2009 23' FB Flying Cloud
Bromont , Quebec
Brake problem
I everybody,
I want to know where is the fuse in the AS flying cloud 23 fb 2008 between the batterie and the brakes. Actually I have no brake working and I Think à made a short and blow a fuse.
Tanks in advance
Jean Beauregard
2008 FC 23 FB
Mercedes ML 350 blurted
Mejean is offline   Reply With Quote
Old 06-30-2019, 01:10 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
When hooked up for towing the TV powers the brakes. You need to check the brake output on the 7 pin connector. I do not think the wire from the TV to the brakes is fused on the Airstream, but do not know for sure. One way to check the brakes for wiring and function is to disconnect the connector to the TV, raise a wheel, and pull the break away switch
I have had broken wires in the trailer cord. .
Brake controller or trailer brake problem? (newbie alert) jornvango Brakes & Brake Controllers 2 11-01-2012 02:17 PM
Condensation problem...big problem MonaxLisa General Repair Forum 16 10-31-2010 10:00 PM
Brake Problem moveinon Brakes & Brake Controllers 3 04-26-2004 08:00 AM
Battery problem or converter problem Paul Daugherty Airstream Motorhome Forums 31 07-01-2003 06:16 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
