Old 06-17-2013, 03:02 PM   #1
MJBear's Avatar
2000 31' Excella
St Michaels , Maryland
Black water tank valve stuck open
Just purchased a 2000 31' classic. Nice in all ways except this one. The valve was left open when not used and now it is stuck. Have sprayed lots of water in tank but no success. Any good ideas? Can't use system till we get it closed
MJBear is offline   Reply With Quote
Old 06-17-2013, 03:57 PM   #2
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
You can buy a fitting that will fit on the end of your dump pipe that has it's own shut-off valve and even a hose fitting for back flushing the tank. It will allow you to fill the tank and let it soak to see if you can free the valve. If not, the valve will need to be replaced, but the flush fitting is still a good tool for backflushing when traveling.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 06-17-2013, 04:06 PM   #3
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Inconvenient, but not that hard to repair. (If the tank is empty it's also a LOT less messy.) There are only 4 bolts that hold the blade valve in place. You can buy easily by a replacement...and be sure and replace the 2 O-rings...use silicone grease on the whole assembly and you will be good to go.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-17-2013, 05:28 PM   #4
MJBear's Avatar
2000 31' Excella
Thanks for the solution, the tank is flushed and cleaned, how do you get to the valve, it is enclosed in a metal box, I guess the metal pan has to be dropped to access the valves ??? If I drop the pan will replace both valves.
Old 06-17-2013, 06:13 PM   #5
loreepeter's Avatar
2004 30' Land Yacht Gas 30
, OH
with the above mentioned fitting with its own shut off u are good to use RV. however, if u wish u can try to clean the slot the blade slides to close to opening. I use a # 14 stripped copper wire bent with a small 90 degree end. working it up and down each side of the slides to remove anything in the groove. I then dab DOW # 111 along and inside both grooves. Also, a little #111 on the exposed shaft. This should allow the slide to move very easily. Might have to push a little hard to get the shaft and blade off their binding spot. Once a year maintenance and excellent results.
pff
gonagn
loreepeter is offline   Reply With Quote
Old 06-17-2013, 06:43 PM   #6
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
The Airstream factory made a repair to our black tank valve last year. Rather than drop the entire belly pan they simply cut about a 16" X 16" section out of the pan to access the valve.
After the repair was made the technician used a slightly larger piece of sheet metal - maybe 18" X 18" - and attached the new "cover" to the original belly pan with sheet metal screws.
There may be better ways to access the valves but this seemed like a reasonable solution to me.
Lucius and Danielle
1992 29' Excella Classic
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 06-17-2013, 08:09 PM   #7
SStar's Avatar
2004 28' Classic
Midland , Texas
I would try this solution before cutting shopping repairing. You may need a Thetford to Valterra adaptor for your sewer line then a valve with Valterra fitting. Valterra hoses and fittings are a lot easier to find that Thetford. Attach the valve then partially fill the tank with water and a cleaning solution then go drive around. The problem might cure itself. It will at least be usable for the short term with the outside valve in place.
SStar is offline   Reply With Quote
Old 06-18-2013, 10:40 AM   #8
2004 25' Safari
prattville , Alabama
Black tank valve stuck
My valve stuck half open. I used the flush fitting others have talked about poured in about a half cup of Murphy's oil soap then filled tank about half way.
Let it sit six hrs then slowly pulled on the valve handle back and forth small amounts until in worked loose. Has worked fine since. Best of Luck.
bearrand is offline   Reply With Quote
