Old 10-26-2014, 06:44 AM   #1
Angry Black tank level sensor shows full all the time
Good Morning
Just bought a 1979 Ambassador and checking all the systems out.
The black tank level sensor on the dispal panel shows full all the time even though we dumped it twice with clear results the last time.
Any ideas?
copper4713 is offline   Reply With Quote
Old 10-26-2014, 07:09 AM   #2
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
Sensors get clogged with 'grunge'. I worried about mine for the longest time, until I realized I can actually see/hear the level when I flush if I pay attention. Does your commode sit right over the black tank? If so, sensors not really necessary. A flashlight is all you need. There are products that might help clean them, but not worth the expense when you can see at a glance. Best is to get on and enjoy your Ambassador! Welcome to the Forums!
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 10-26-2014, 07:12 AM   #3
Thanks so much Phillip. Great advice
Old 10-26-2014, 04:38 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Yep, the water level sensors of old are notorious for false readings or no readings. You might try adding 10 pounds of ice cubes and then filling your black tank with water about 90% full and adding some cleaner (I use dish soap). Then go for a nice hour long drive with your Airstream in tow to slosh around the ice and soapy water. There is a small chance it will clean the upper most sensor. Pick a curvey, bumpy road.
The good news is you can add the Garnett SeeLevel tank monitoring system to your trailer with quite a bit of work. These sensors adhere to the outside of the tank and are wired to the display unit. I installed them on my 66 Trade Wind with good results, and I think they will be quite reliable through the years.
Or you can use the less expensive flashlight and worry about something else.
David
Old 10-26-2014, 05:35 PM   #5
2011 30' Flying Cloud
Arvada , Colorado
MY sensor does not work properly for the black tank. It will read empty until it starts getting close to full. One adjustment attempt did not work. I don't worry too much about it based on our experience in how often we need to dump the black tank.
Jack46 is offline   Reply With Quote
Old 10-27-2014, 10:10 AM   #6
Arvada , Colorado
Yea, the flashlight "sensor" works great too. We did have an interesting experience one time. Sensor light was green. My wife gets up at night to use the facility and she comes back and taps me on the shoulder. "I think we have a problem" Checked toilet and it was full to just below the valve. Sensor light is now reading bright red. So, the lesson is that we do need to do a visual check fairly often.
Old 10-27-2014, 12:39 PM   #7
2010 22' Sport
Boise , Idaho
I'm on my second Airstream, a 2010 Sport. The sensor on our brand new Sport worked for about a month, then stopped working. The sensor on our older AS Land Yacht motorhome never did work! Our dealer told us that broken sensors is not at all unusual.
baldwin6601 is offline   Reply With Quote
Old 10-27-2014, 01:28 PM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
The Garnett SeeLevel is a more modern way to sense fluid levels. I think some models of newer Airstreams have this system.
Here is a photo of my 86 sensors, well at least the wires to them, and a photo of the SeeLevel being installed on tanks for my 66. My new tanks came with old style sensors molded into them. You can see the 4 buttons on the left side. I opted for the SeeLevel just to see how well it worked.
David
Name:	1205 New Valtera Gray Tank Valve.jpg
ID:	225234   Click image for larger version
Name:	1404 Waste Tanks See Level Senders.jpg
Old 10-27-2014, 03:11 PM   #9
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
I think the notion of working level sensors in our trailers is just an effort of the RV Industry to mess with our heads ......
A few trips under your belt will give you all the knowledge you need about how long it takes to fill both the black and grey water tanks. The flashlight simply becomes reassurance and fine tuning .....
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 10-27-2014, 03:14 PM   #10
2010 22' Sport
Boise , Idaho
Ranger Jay you are dead on IMO
Old 10-27-2014, 03:21 PM   #11
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Yah but, it's 9pm and we wonder if we have enough room in the gray tank for a shower. Accurate information is handy at times. And the Trade Wind has just 25 gallons of gray capacity.
David
Old 10-27-2014, 03:37 PM   #12
RangerJay's Avatar
2002 19' Bambi
Images: 44
David
Over the years we've ended up landing on water "units" - i.e. a sinkload of dishwater is a single "unit" and a military shower is another "unit" - and we know pretty much exactly how many units it takes to fill the grey tank - so - at any time we will know what we will have left ..... sounds silly ..... but it works ..... haven't overflowed the tank in years ..... course we don't have grandchildren or teenage daughters ...... think that might screw the system up royally.
Jay
(Oscar Wilde)
Tank Level Sensor - Just Learned Something AirsDream Plumbing - Systems & Fixtures 3 06-26-2011 04:15 PM
Fresh water tank: Level sensor wires Keyair Fresh Water Systems 6 12-18-2010 11:12 PM
black water sensor reads 3/8th all the time javamaude Waste Systems, Tanks & Totes 18 10-09-2009 01:46 PM
Level Sensor - Black water holding tank. mharrison@ie Waste Systems, Tanks & Totes 3 12-31-2007 06:09 PM
Black Water Tank Shows Full When Empty yochanan Waste Systems, Tanks & Totes 12 01-21-2006 10:41 PM
