Old 11-10-2014, 06:25 PM   #1
Bird Poop
Is there anything I can use to get the bird poop stains of my shiny Streamline? I tried using a little vinegar and baking soda but it doesn't remove the stain. The stain almost seems deeply embedded.
Trixella is offline   Reply With Quote
Old 11-12-2014, 08:35 AM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Several years ago at an RV show we bought a spray cleaner called "Holy Cow". That stuff really works to remove stains, bugs, etc. It was on the warehouse inventory list of Ace Hardware, and I remember ordering a case of 4 gallon jugs. I understand that the manufacture of it has been discontinued, but there is always the possibility that some may still be available at Ace Hardware - they may not have it in the store, but they may be able to order it from their warehouse.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 11-12-2014, 08:41 AM   #3
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
I have had good success with Meguiar's Cleaner/Wax on my wife's Miata, which is British Racing Green, and shows every little bird poop stain, tree sap, etc. I see no reason why this product would not work on the Airstream, although I have not yet tried it.
Cannonball is offline   Reply With Quote
Old 11-12-2014, 09:41 AM   #4
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
I've just finished polishing and haven't tried anything on the newly polished surface yet, but I used rubbing alcohol to get off the bird poop and sap before polishing. I would think the same would work on the polished surface also. It definitely dissolves the poop!
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 11-12-2014, 02:07 PM   #5
It appears that there are several different kinds to choose from....
https://www.google.com/search?q=holy...el=sb&tbm=shop
Which one do you have?
Old 11-15-2014, 09:41 AM   #6
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
We have both the pink and the green. The pink is the one I use mostly; the green is for greasy and oily stuff.
VE3JDZ
AIR 12148
Old 11-15-2014, 10:52 AM   #7
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
If it has stained the aluminum and it sounds like it has use a motorcycle exhaust debluer such as Blujob (Ebay).Designed to remove stains from brightly polished aluminum.You will waste your time with cleaners if it is stained.
White powdery stuff that looks like bird poop whacksplat 2008 Safari SE 7 02-24-2010 11:36 PM
Bird Poop on Skin kitchenclose Cleaning, Stripping & Polishing 8 05-23-2009 09:48 AM
the straight inverter poop? Lumatic Batteries, Univolts, Converters & Inverters 12 12-11-2008 07:06 PM
poop line? osolow Waste Systems, Tanks & Totes 8 03-22-2008 06:16 PM
Phred Poop Sheets, check it out. donnall General Motorhome Topics 9 08-17-2004 12:05 PM
