Old 07-29-2015, 03:35 PM   #1
Big Decision!
Hi All:
I bought a 1975 Land Yacht for $6,500 and I now know it needs a new chassis as nothing is salvageable from it.
I have 3 options:
1) use a 2005 Terry Trailer chassis for free
2) buy a new one from Airstream (will add an additional $4500)
3) try to sell the 1975 at a loss and buy the same model but 1965 that seems to have a good chassis with the floor redone, fully polished for 10,500)
I'm new to this world so any advice is greatly appreciated.
Warmest,
Ryan
beckettnole is offline   Reply With Quote
Old 07-29-2015, 04:16 PM   #2
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Just to clarify, are you referring the "chassis" to the entire frame of the trailer, or to the axle? If you use the Terry trailer one, will it actually fit?
Mrs. NorCal Bambi traveling in S Tardis ~ from the Great State of Jefferson!
My blogs: http://yrekahistory.blogspot.com
http://siskiyoucountycamping.blogspot.com
http://campingalongi-5.blogspot.com/
CaddyGrn is offline   Reply With Quote
Old 07-29-2015, 04:27 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Sell it and move on....
CRH is offline   Reply With Quote
Old 07-29-2015, 04:45 PM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Assuming that you are using the term chassis correctly, if you really paid $6,500 for this model of trailer that needs a new chassis, I'm sorry to say that you were seriously ripped off.
Bob Martel
WBCCI# 5766
Old 07-29-2015, 07:54 PM   #5
Yes, the Terry trailer can be cut to fit and the lug pattern is the same....it will have a leaf suspension and a different axle than what is typically on Airstreams
Yes it definitely was a poor purchase but there was no way to know how bad until I took it apart.
Old 07-29-2015, 08:13 PM   #6
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Another option could be to get a welder to fabricate a chassis for you. I've no idea how that cost would relate to the $4500 chassis from Airstream, but there are a number of restoration threads on the forums where people have done this. Are you located anywhere near the factory? Can you post photos of the frame damage?
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 07-30-2015, 05:40 AM   #7
Chelsea , Michigan
Images: 12
1960's vs. 1970's
Back to your original question, sink another $4,500 into the 1975 to get a good chassis (and presumably still have all the other restoration issues to address) or get rid of it and buy a 1965 with a good chassis and some restoration already started for $10,500. To this question I would vote for the 1965 because if you invest in a new chassis for the 1975 you will be in the same place in terms of your investment as going with the 1965 but, by going with the 1965, you will have a more valuable trailer when done since restored 1960's trailers are generally more choice than are 1970's vintage.
Of course the trailer model comes into play, with the shorter vintage trailers being even more desirable than longer ones despite their limitations for actual camping vs. the longer ones. Also, presumably you will recoup some money on the disposition of the 1970's trailer to help offset the purchase of the 1960's. However, if you get a savvy buyer for the 1970 model, be prepared to get half or less what you paid for it given the reported condition of the chassis.
Bob Martel
WBCCI# 5766
Old 07-30-2015, 06:20 AM   #8
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
IMO it would depend on how much you are willing to spend. While it appears as though you spent too much for the '75 if you spent another $4500 and could afford to do so, you would have a new reliable chassis.
If you buy the '65 you would have to start all over again.
If I were spending your money I would get the new chassis from AS. :-)
Old 07-30-2015, 06:43 AM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Before you make any more big $$ decisions go out and get some bids for a replacement frame from some of your local welding shops. Also decide if you do go this route, if you have the necessary skills to remove the shell or will you be contracting this out also. Just because the 65 claims to have a good frame doesn't mean it does, don't get pulled into it by a shiny shell.
Old 07-31-2015, 09:27 AM   #10
All good advice, thank you very much
Old 07-31-2015, 03:49 PM   #11
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Check out Millertime's thread here. Seems like he got a whole new frame made for under $3K, if I recall correctly,
Old 08-12-2015, 09:29 AM   #12
Thank you everyone, I think I'm going to try to sell the 70s and get into the 60s......that said I may put the Terry trailer on 70s, redo the floor, and shine her up to maximize what I can get for her
Old 08-29-2015, 09:20 AM   #13
Update: leaning toward getting a welder to fabricate the trailer for me, shine her and then I will try to sell her so I can get into the 60s Airstream
Old 08-29-2015, 11:29 AM   #14
Old chassis are 4 inches thick.
Your newer coach has a 5 inch chassis.
An old chassis on a newer trailer is a no-no.
How big is too big? Newbie Ponderings... mattlyon Our Community 22 08-15-2010 08:32 PM
Figuring out how big is big enough Marquette 2006 - 2010 International 24 11-09-2007 08:27 AM
Big storm = Big dent TennisMan 2007 Safari SE 10 07-17-2007 09:20 AM
Need Help In A Big Decision M.h. gallion Mechanics Corner - Engines, Transmission & More... 3 06-09-2007 06:53 PM
BIG BIG AIR HUG!!! & "eh" Streamin' THANKS GT1963 Our Community 6 01-30-2004 07:50 AM
