Old 08-29-2015, 07:03 PM   #1
Unka Jack's Avatar
Fonthill , Ontario
Best way to remove Olympic rivets?
Just wondering what the best methods for removing Olympic rivet are? I have access to both side of the rivets.
Although it seem like I know what I'm doing, I'm just standing on the shoulders of giants who have done this before and kindly posted their journey.
Cheers,
Jack
73's VE3ZPW
Unka Jack is offline   Reply With Quote
Old 08-29-2015, 07:37 PM   #2
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
I got Vintage Trailer Supply's handy-dandy rivet removal tool:
Rivet Removal Tool
It works great, but be sure to wear gloves while using it, otherwise you risk taking a chunk out of the web between your thumb and index finger.
Slats is offline   Reply With Quote
Old 08-29-2015, 07:41 PM   #3
Slats's Avatar
1966 24' Tradewind
.....or you can buy the same thing from an aircraft supply company for only $20 more:
rivet removal tool from Aircraft Tool Supply
Old 08-29-2015, 08:09 PM   #4
Unka Jack's Avatar
Fonthill , Ontario
So your saying to just drill them out like other rivets?
Cheers,
Jack
73's VE3ZPW
Old 08-29-2015, 08:15 PM   #5
Mission , Texas
Yep ... no special tool needed - only a drill and same size drill bit.
nrgtrakr is offline   Reply With Quote
Old 08-29-2015, 08:39 PM   #6
Unka Jack's Avatar
Fonthill , Ontario
And here I thought there might be a better way to remove them from the back without having to drill through the old mandrel.
Cheers,
Jack
73's VE3ZPW
Old 08-29-2015, 08:54 PM   #7
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
It can be difficult to get a drill started on an Olympic....can be helpful to use a punch and tap the mandrel in a bit. Will give you a better start with drill and avoid slipping and wounding the aluminum shell. Same goes with a bucked rivet...the punch will give your drill a better start.
arktos55343 is offline   Reply With Quote
Old 08-29-2015, 09:32 PM   #8
Mission , Texas
I like this video from thesignlady ...
Buck Rivets or Olympic Rivets halimer Ribs, Skins & Rivets 5 09-21-2011 03:20 AM
What's the best way to remove rivets? Husker Dave Ribs, Skins & Rivets 7 06-22-2010 08:13 AM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
