Old 04-04-2016, 04:10 PM   #1
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Best way to jack up an Aistream 25 ft
Replacing my GYM tires later this week & curious as to the proper procedure to jack up using a floor jack. I want to make sure the installer does it correct. Thanks,
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 04-04-2016, 04:12 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Use the designated jacking points.
MICHAEL
Old 04-04-2016, 04:15 PM   #3
Mrjkq's Avatar
Venice , Florida
Witch are?
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 04-04-2016, 04:20 PM   #4
Llando88's Avatar
2016 30' Flying Cloud
Originally Posted by Mrjkq View Post
Witch are?
Check in your manual, should be as described.
On mine (27' FC) they are about 1' inboard of the large 'JACK' label on either side.
Look for a small (3" or so) square plate.
But, again, this should be in the manual.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 04-04-2016, 04:30 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You can also pull one wheel at a time onto boards or blocks and the other wheel will lift into the air for changing. I think that's the easiest and safest. Some people jack them under the axle mounting plate.
The most important thing is to never, ever put a jack under the axles themselves as that can bend the axle.
Doug and Cheryl
Old 04-04-2016, 04:59 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Never did trust the DJP's....
Every Winter it gets 'jacked' here....
ID:	260036   Click image for larger version
Name:	2007 WINTERIZE 007.jpg
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 04-04-2016, 05:01 PM   #7
AWCHIEF's Avatar
Images: 33
Yep, crappy manuals but they do contain some good information for some light reading.
MICHAEL
Old 04-04-2016, 05:04 PM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I always jack from the designated points, placing a small block of wood between the jack and the belly pan.
2012 Dodge Durango Hemi/AWD
Old 04-04-2016, 05:20 PM   #9
AirstreamJim's Avatar
2007 25' Safari FB SE
Baldwin Harbor , New York
I looked and looked and looked again for the jack point label on my '07 Safari 25FB but it was nowhere to be found. I told the tire installer to use 4 floor jacks, one fore and aft of the axles on each side, under the main frame rails.
WBCCI 1433
Long Island, NY
Silver Meteor - 2007 Airstream Safari SE LS 25FB
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Old 04-04-2016, 05:47 PM   #10
Long Island , New York
Jim sounds like your frame rails are exposed? Not so on our FC20 and many newer trailers with a bottom skin under the framing. Jack points labeled and detailed in the manual. Does your manual say anything about jacking the trailer up?
Peter
Old 04-04-2016, 06:08 PM   #11
Mrjkq's Avatar
Venice , Florida
Tomorrow I'll look for the jack points but not sure I'll find any as the belly pan covers everything. Think I'll call customer service in JC.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 04-04-2016, 06:15 PM   #12
Well I'll be damned. I'm feeling quite stupid right now. You see, of all the things I looked at - and I thought I touched/played with everything - I didn't look critically at the belly pan when I picked up the Airstream 3 weeks ago. I looked underneath, and it somehow didn't register that I could see everything!
Yes, my frame rails are exposed. There is no belly pan. All the tanks are out there in plain sight. The thing is, there's no evidence (like rivet holes) that there ever was one.
So now what? What's it going to cost to have it replaced? Jeez!
WBCCI 1433
Long Island, NY
Old 04-04-2016, 06:36 PM   #13
SeaLevel's Avatar
Jupiter , Florida
We have the same model Joe. If you look underneath near the stabilizer jacks in the back you should see the "Jack" with an arrow pointing to the jacking point. Look at this video. At 9:20 into it Patrick points it out:
SeaLevel is offline   Reply With Quote
Old 04-04-2016, 06:37 PM   #14
Jim, maybe your 2007 model never had a belly pan? What does your manual say about jacking up the trailer?
On page 42 of 103 in this 2007 Safari manual, it refers to Jack labels on the underbelly pointing to jack points:
https://www.airstream.com/wp-content...safari2007.pdf
Although these online manuals often differ from the hard copy in your trailer.
"To CHANGE A TIRE with a jack see the label affixed to the underbelly to the rear of the wheels. This label, says JACK with an arrow and points to a plate riveted to the mainframe rail where the jack head must be placed. A flat tire may also be change without the aid of a jack. Drive the unit up on a ramp 8’ wide, 6” high, and about 3 feet long at its base. Position the good tire on the ramp. This will raise the flat tire clear of the ground."
Aistream 2004 Intl CCD Electric jack problem danyfr67 Jacks, Stabilizers, Lifting and Leveling 8 04-08-2011 08:33 PM
aistream service centers.. safari05-25 On The Road... 6 10-22-2006 06:38 PM
Rock Guards for Aistream a-wanabbee Rock Guards, Segment & Window Protectors 3 03-16-2006 07:29 PM
Aistream Book codybear Off Topic Forum 4 03-16-2006 03:50 PM
Aistream anounces several new products.... crazylev Our Community 0 07-01-2005 11:34 AM
