Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-04-2016, 08:10 PM   #21
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Tire companies are not all competent. Many will do thousands of dollars of damage to your unit, if you do not properly supervise them. Use the ramps or stair-step leveling blocks to be safe. Do not let them use their air wrenches to tighten your lug nuts.
Old 04-04-2016, 08:13 PM   #22
"Cloudsplitter"
Thumbs up
Never realized I was so rong......for so long
Thank You...
Old 04-04-2016, 09:09 PM   #23
Sag Harbor , New York
Noted -- front OEM trailer motorized tongue jack on the ground, and no new jacks between it and the front tires. With superior knowledge of Airstream structure and suspensions, clearly you know where to put jack stands safely, so the tires can be removed entirely. Newcomers may not have your level of knowledge. When in doubt, follow the owner's manual IMO.
Old 04-05-2016, 10:12 AM   #24
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
No matter who it is, I don't trust a jack on my AS, and I have used this product many times and it works flawlessly.
http://www.genuinehotrod.com/itemgroup/trailer-aid
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 04-05-2016, 10:20 AM   #25
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I use Trailer Aid ramps on both sides.
Back the rear tires up onto the ramps.
Change the front wheels.
Drive the front tires onto the ramps.
Change the back tires.
Seems like less work and safer than a floor jack to me-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-05-2016, 10:23 AM   #26
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Why not just use the ramp method at home and do it yourself. It is entirely safe, real easy, and lets you get familiar with the process should you ever have a trailer flat out on the road.
Doug and Cheryl
Old 04-05-2016, 10:50 AM   #27
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
When I had my Casita I had new tires installed and the techs wanted to jack the trailer up from the Dexter axles. Luckily I was supervising but they gave me an argument before they complied. Never trust a tire tech who listens to grudge music in the background.
The company that installed my Michelins on the Airstream jack it up in the same manner as Robert showed.
For me it appears the ramp method is the safest and easiest.
Kelvin
Old 04-05-2016, 12:29 PM   #28
2016 30' Classic
Santa Rosa , California
Wow...I wonder, if the belly pan is missing, maybe the jack point plates and labels are missing too
phann is offline   Reply With Quote
Old 04-05-2016, 01:38 PM   #29
2012 23' FB International
Woodstock , Ontario
So now what? What's it going to cost to have it replaced? Jeez!
There is no belly pan under the water tank, and you did in fact find the acceptable jack points. Most older units do not have a "jack " label. I always jack under the steel frame member that holds the axles, just behind or in front of the wheel I want to remove. Just be sure to get it centered and if need be put a hardwood block in top of the jack, as some jacks may dent or bend the frame member if not accurately lined up. Also chock the opposite side wheels so the trailer won't roll or twist of the jack. As noted, you can pull one wheel off the ground with blocks under the adjacent wheel. I usually pull up on about two or 3 inches of block to take the pressure of the wheel I want to remove. That way the wheel is still on the ground to break the stud nuts and then raise it the rest of the way with the jack. Reverse to drop the wheel after installation so you can tighten the nuts and then pull off the blocks.
JCW
JCWDCW is offline   Reply With Quote
Old 04-05-2016, 03:17 PM   #30
1976 31' Sovereign
Oswego , Illinois
I have stated on forums many times, I will not jack up a tandem axle trailer of any kind nor use jack stands as they can and will slip. I have heavy duty truck stands and they have slipped. For safety I will only use ramps, wheels properly blocked. Blocks on stands in my opinion makes them unstable. Some one stated doesn't trust ramps only jacks. I hope he isn't under trailer if slips, if any one has worked is safety will tell you jacks can and do slip.
Old 04-05-2016, 04:27 PM   #31
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Originally Posted by SeaLevel View Post
We have the same model Joe. If you look underneath near the stabilizer jacks in the back you should see the "Jack" with an arrow pointing to the jacking point. Look at this video. At 9:20 into it Patrick points it out:
THANK YOU, the video answers my issue!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 04-06-2016, 03:50 AM   #32
Originally Posted by AirstreamJim View Post
I'm thinking it would be a one-of-a-kind Airstream if it didn't. I'll be calling JC tomorrow to ask, but I'm sure I know the answer.
Even though I bought it through a dealer (consignment sale), I've had contact with the PO. I just emailed him to ask whether the belly pan was in place when he bought the trailer.
This has me...perturbed.
An understandable state of mind!
Wondering Jim if JC or the PO gave you any satisfaction on this? Or maybe the dealer . . .
Peter
Old 04-06-2016, 03:52 AM   #33
Wondering if you also saw the pages referenced earlier in your owner's manual?
Old 04-06-2016, 07:04 AM   #34
AirstreamJim's Avatar
2009 34' Classic
Lake Worth Beach , Florida
Let's call it a case of "ready...fire...aim" and leave it at that.
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2009 Airstream Classic Limited 34
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Old 04-06-2016, 09:00 AM   #35
Sorry 'bout that . . . groan . . .
Old 04-06-2016, 09:20 AM   #36
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
When I jack the trailer I have it hitched. The tow vehicle makes a pretty good chock.
2019 Ford Expedition Platinum
Old 04-06-2016, 09:43 AM   #37
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 101
Anderson rapid jack - works like a charm....
1964 Globetrotter | 2023 Nissan Armada
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 01-30-2018, 05:22 PM   #38
Mollysdad's Avatar
Now, why didn't I think of that? A Trailer Aid is cheaper than jack stands, when getting two wheels off.
I was fixated on changing the left two then the right two.
Brilliant!
Old 01-30-2018, 06:46 PM   #39
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
So this was probably covered and I read through twice but. My tire store is an hour away and I only want to make one trip to have the tires changed. Can I safely put jack stands under the frame rails using the front jack as a tripod? Or should I use 4 and space them out?
25ft fb. By the way.
gandttimes is offline   Reply With Quote
Aistream 2004 Intl CCD Electric jack problem danyfr67 Jacks, Stabilizers, Lifting and Leveling 8 04-08-2011 08:33 PM
aistream service centers.. safari05-25 On The Road... 6 10-22-2006 06:38 PM
Rock Guards for Aistream a-wanabbee Rock Guards, Segment & Window Protectors 3 03-16-2006 07:29 PM
Aistream Book codybear Off Topic Forum 4 03-16-2006 03:50 PM
Aistream anounces several new products.... crazylev Our Community 0 07-01-2005 11:34 AM
